I have a rattle/tappy sound and i have a video for yoU!! (you love me right?)
nismoracingsx
Car: 1993 White 240sx Coupe
Okie dokie, today I decided to finally replace my valve cover gasket (not in class right now so laziness is at an all time high). Replace the gasket no probs, but is the top chain guide supposed to be plastic or metal? Feel like a tard for askin
ANYWAYS, chain guide looked fine so I left it alone, but i did notice that my car still has a rattle/tapping sound (not quite sure how to describe it). So I went ahead and grabbed the camera and made a quick little video..
NOTE: Its not this loud in real life, i noticed my motor sounds like a 747 on this video and the weird camera turning at the beginning is because i'm trying to aim the microphone part at the motor
http://s89.photobucket.com/alb...e.flv
interior shot was just to show that idle was sitting @ 750ish for video
Modified by nismoracingsx at 10:32 PM 9/12/2007
nismoracingsx
bumpity, noone gimme some advice?
LayNLow240
Car: 92 240 coupe
Video doesn't work.
nismoracingsx
fixed
PaddyOneThree
Car: 1993 240sx coupe
sounds like the timing chain guides to me
Valett85
Car: nissan 240sx se (93 240sx se and 95 240 sx se)
yeah, i think we all have that problem, if u have that motor. ive looked into it. their are three rails. take to top one off no problem but the other ones look a little more challenging. i havnt takled this problem yet so... if you do, let me know what happens
L1lLPANDA
the same thing happens to my car!and mines an auto too it happens only sometimes though and only like for 10 minutes. my car barely started doing that too.
BUMP cause i wanna know why its doing this :]
PhopsonNY
Car: 1989 Nissan 240SX
Dude,
do us a favor... let us know what the problem and solution was so others can learn from your experience
CrypticScorpio
Car: 1992 240sx SE Hatch
YOUR PROBLEM AND SOLUTION!Timing chain guide. remove the top guide its of no use. DONT REMOVE the others!!!!!!there a DIY Search for itlastly no flamming intended but this is a common problem and many have fixed it before. _Search_
if thats not it check to se if anything is hitting off your fan or belts or check your fan pully assy. that happened to my Generator a while back till it broke right off... big mess after that. so if it the pully get it fixed asap
VinceSez
Car: 1992 Nissan 240sx
probably guides, i removed just the top one, (the one you can see right when you remove the valve cover) and it hasn't made that noise since.
