Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Sat Apr 12, 2003 9:57 am
If there was oil where the clutch meets the flywheel, it would be slipping all the time, not just after half hour, right? The freeplay thing sounds right though... did you adjust it when you put in the new clutch? If not, it's not too hard to do, you have to adjust the pin that goes into the master cylinder, it's on the top of the clutch pedal.
