I have a problem with my audio..pleaseeee help....
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Lunatic1120
Car: G35 Coupe
So I have a 04 g35 coupe...with a 6 cd changer..so here is my problem..when I play a cd..my driver side speaker doesn't play right...like I don't hear the music playing right..but when I play a cassette it's okay..or even the radio..it plays fine..only when I play a cd that happens..does anyone know what's the problem???
LuckyLuke
Car: G37s - HKS Exhaust - R2C Performance Intake
maybe you songs are low quality when you burned it.. don't know..
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Your CD player is corrupted or something, you may want to get a double din or some DVD/Nav combo.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Its the head unit. They have issues. I'd buy double din...
pfarmer
Car: 2008 GXS with technology package
Lunatic1120 wrote:So I have a 04 g35 coupe...with a 6 cd changer..so here is my problem..when I play a cd..my driver side speaker doesn't play right...like I don't hear the music playing right..but when I play a cassette it's okay..or even the radio..it plays fine..only when I play a cd that happens..does anyone know what's the problem???
No one can tell you what is really wrong without direct access to the unit. It could be as simple as a loose connector. What I would consider doing is checking all of the connections, especially from the changer to the main unit. It may well be a simple fix.
As another user mentioned you could also replace it. To me it is a matter of how much integration there is in this unit and the car as I have not really seen it more than in pictures. If it is minimal then replacing it may actually be cheaper and/or give you a much better unit for very little additional cost.
If you like the current unit and there is little wrong with it then it may well be worth keeping it and fixing what ails it.
One benefit of replacing it is that you can go to a more easily to upgrade unit right down to speakers and after market amps. One thing to keep in mind is the total package. That is if you want to 'net' parts of it together then you want to make sure you have that capability and that the other netted units have what you need like xm, etc.
For example in my other car I have Pioneer. A simple cable goes to the back of the car and connects into the xm module and cd player. You can add multiple players and also different models of players such as a 6 disc which I have or a 12 disc which I do not. Other brands work similar.
I tend to prefer something that is not 'all in one box'. That is I don't like a television with a dvd player in it (the player dies and you have issues), the same goes here. Some makes sense such as a nav unit that utilizes the same display as the radio.
Perry
kalinvelev
Car: 2004 Infiniti G35 Coupe 6MT
I had the same problem! I was lucky to get everything replaced under warranty.
dougiefresh7988
Car: 2005 infiniti g35x sedan
2008 infiniti g35xS sedan
i have a similar problem my 6 disc in my 05 g sedan stopped playing cd's and shuts off when ever it wants i pulled the unit and found nothing i hear they are notorious for failure best bet get a aftermarket head unit.
good luck Doug
dougiefresh7988
just had the unit replaced works great dealer si the way to go just inspect the job they did becasue they f***ed up the shifter cover on ym car takin it off and didnt put the climate controll screen back in all the way i raised hell w the dealer so they ordered me a new cover and put the car back together the right way
Return to “G35 and G37 Interior, Exterior and Audio”
