tackie33 wrote: have a 2006 Murano and when I was driving it down the highway tonight it sprayed Transmission fluid all over...then when I stopped it the rest of the transmission fluid poured on the ground. When I put it in Drive it barely goes. I just had to park it and will have it towed tomorrow...does anyone have any ideas what it could be???
First, you're in the wrong thread, this is for 2003 CVT problems.
But to answer your question, you obviously blew a seal, nothing subtle about this problem, and I sure hope you didn't even attempt to drive it after you realized all the fluid leaked out, if you did I can't say I have a lot of sympathy for you, and it could be an expensive fix at 5000 dollars or more to replace the CVT, hopefully you still have powertrain warranty left.
