drzm0st1ll3st »
https://forums.nicoclub.com/drzm0st1ll3st-u131291.html
Fri Dec 18, 2009 6:51 am
hey NICOCLUB how are you guys? my names Eddy, and Ive been lurking the forums for quite a while now (months) ive been here for almost about a year but never really posted anything.
well onto my problem.
i have a 90 piggy with the single slammer that doesnt want to turn on. so what happened was ive been having some problems here and there like having the car leaking gas when i fill it up.. but thats not the main concern for now
my car has not turned on for more than a month and i will explain what it is that happened..
It always turned on without problems. The day it stopped working, i had my car down my block. i turned it on without hesitation, working fine. drove it up the block fine no problem, pulled up to my driveway, charged my dads car with it (ive done this plenty of times and never had any problems with it.) so his car turns on after about 20 seconds of charge.. i backed up to the street, turned my car off,, check my oil level because it has been suckin up oil and i know my gasket is going.. but w.e. it stil worked fine.. while it was off, i added more oil, but im not sure if this is the main cause, i had 10w40 in it and i added about half a quart of 10w30 oil in it. i checked the oil and it went to the max. now i know its not completely fill until i turn the car on and let it circulate for a bit. after all this, i put the cap on and the dipstick back on, and tried to turn it on. this is when it was just cranking but didnt turn on. and about 5 minutes before that it turned on just fine!!
so i was there trying to turn it on for about 5 mins,, and i checked everything in the bay and everything was fine. i had my friend check it out and we found out the fuel pump fuse blew, i replaced it, and still it doesnt turn on. i hear the FP whirring when it is in the ON position. i have checked the battery, charged it, still nothing. i have NGK spark plug wires and spark plugs, checked the spark plugs and they were shot, so those were replaced. still nothing
so far ive done the following with no luck:charged batterychanged spark plugs (same one just new)changed spark plug cableschanged FP fuse
what ive also want to add is that the car cranks but doesnt start, and it was unexpected, so can it be my oil since i added 2 different types in it even thought it was mostly 10w40 and a little 10w30?
im on a supertight budget and i need my car asap! i would love to fix it for xmas. i dnt have money to tow it to a mechanic, and have them fix it. i dont have money to be replacing stuff and the car still not work. i just want it to work for me to get to school
its a ka24e btw.
ANY HELP WOULD BE GREATLY APPRECIATED AND YES I HAVE SEARCHED AND SEARCHED AND SEARCHED WITH NO LUCK!!
THANK YOU NICOCLUB
Modified by drzm0st1ll3st at 5:47 PM 12/28/2009
