I have a problem....
KAmakazi
Car: 1996 240sx
My problem is similar to a recent poster... i have a 1996 coupe
When i turned my key off one day everything turned off(light stereo etc.) i was like wtf so i tried to start again but nothing happened. The only thing that would turn on was my dashboard clock.
I had to leave for a week and when i came back i tried to crank it again just for kicks and it started right up....
So i took it around the block and when i came back and turned the key off... boom everthings dead again....
any suggestions... pleae help
240Knightrider
hmmm...so just the clock is on..What about the gauge cluster.
If just the clock sounds like you might have a ground problem or a short somewhere....
KAmakazi
Car: 1996 240sx
Nope, just the clock and when i turn the key to the ON position the clock goes off along w/ the beeping...
Graphfixz
Car: Black 91 240SX Hatch
is there any play on the ignition? Have you looked under the steering column for loose wires?
240Knightrider
You gotta have a short somewhere... or a loose wire. Go over your car and see whats going on.
I would say check the starter but that wouldnt cause none of the lights to come on. Unless your battery is really dead and it can only power the clock...but I dont think thats likely to just do the clock.
KAmakazi
Car: 1996 240sx
Ya i checked all the wires, it ended being the alternator lol. The second time i had it checked it checked bad. Thanks for the input guys.
240Knightrider
Cool, glad you figured it out.
