i have a pop-up headlight problem
jdm_griffin
Car: 240sx coupe
i have a problem with my headlights. the only thing that works are my high beams. they dont go up or down and the lows beams work. and none of my parking lights or blinkers work. it could be a major wiring problem or just some fuses. suggestions?
Nick240sx
Car: 2009 Ford Fusion SE Sport
i hear putting viagra in the gas tank solves this. only last for 2-3 hours though.
jdm_griffin
Car: 240sx coupe
lol that might help. i just gotta hunt some damn wires down.
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
that could either be a fuse, relay, headlight switch/turn signal switch... just a few things to look at to try to fix it
mchkc240
Car: 91,92 Nissan S13 - SOLD
98 BMW E36 - Running
If your fuses are fine then it could be the switch. A lot of people have lights problems and when they plug in their friends switch the problems got solved. You can try that out. Goodluck!
VinceSez
Car: 1992 Nissan 240sx
which switch?? the switch the makes the headlight go up/down, or the switch to turn on the headlights?
Goldeneagle
Car: 1992 240sx Coupe
Check your fuses first.
