I have a noise at startup
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
I noticed this last winter, and I'm starting to notice it again now that it's getting cold. When the car is cold and I start the car, I hear a small screech after startup. My starter is original and the belts have been done less that 2 years ago. Any ideas. I don't want to get stuck.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
a slightly loose belt from cold contraction I'd think a minor retightening will fix it.
qship96
Car: 1996 Infiniti Q45
also check idler pully bearings,which make that noise as first sign of failing
superuber
bullittandy wrote:a slightly loose belt from cold contraction I'd think a minor retightening will fix it.
belts can stretch!
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
I get the same thing; I think its the starter, sometimes when the spline comes out to spin the flywheel it doesn't retract fast enough which causes that noise.
It could be a sign that your starter is going.
I hope mine doesn’t die for quite some time because those things are ridiculously expensive.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
check the play in the belts.... You should be able to pull on the belt about 1/4 inch before it really starts getting tight...
If thats the case its easy enough to tighten the belts....
