? i have a ka24e and gonna boost it
bz240sx
Car: 89 240sx with ka24e-t
ok what is the diffrences in the ka24de and the E or should i say will a de mannifold work on the E
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
You'll need different stuff for a ka24e. Basically it's a single overhead cam motor as opposed to a Dual OHC motor. The SOHC engines seem to take boost just as well as the DOHC (at least at lower PSI levels) but there isn't as much developed for them since there aren't as many out there.
Try searching for Gladman Performance or go here, http://www.jgstools.com/turbo/index2.html, for ka24e manifolds.
Just research research research before you do anything and checkout the KA-T forums on here.
bz240sx
well i have done alot of research and this is the stuff i have allready 32-12-3 inercoolerW/3inch piping. t3/t4 57t 550cc injectors,255fuel pump fuel pressure ragulater, rs type bov,jim wolf cam,jdm fueland boost guages,eprom chip and softwhere, so what else do i need to boost it and i have searched alot to find out if the de manifolds will work on the e but i can't fild anyone who knows . so if you can help me please do thanks brandon
Veriest1
Car: '96 BMW M3
Yes you'll need a different manifold for the E. As far as I know the DE manifold doesn't even line up. Refer to my previous post for people who sell ka24e manifolds.
Are you using a Jim Wolf tune? Do you already have it? If so, what are the details on it?
Which wastegate do you intend to run?
What are your power goals?
How much PSI?
Are you going to run it off the wastegate or use a boost controller?
BTW, welcome to Nico. Your profile says you're a tech who or what are you a tech for Brandon?
nchopp
Moved to the KA forum.
bz240sx
hall ford in va. yes on the jim wolf tune. and 15psi, manual boost controller.external wastegate. i think i can get like 350hp with that but this is my frist time boosting a car . And thanks for the help any sugestion
churro
Car: RHS13 ('89 Hatch)
Just so you know, there are 2 KA24Es. Engines from 012039+ have a compression ratio of 8.6:1, engines before that are 9.1:1. The ID number is located on the exhaust side of the block between cylinders 2 & 3. That's just something to think about when you go boost. 350HP seems high for the stock internals. Good luck.
dickie
Car: Killer Turtle
im moving this to ka-t.
Edub1
Car: 89 240sx KA-T
How much do you plan on doing?
If I had it to do over I would get a DE. There are many advantages and parts are much easier to come by and will go in a lot easier and neater. The SOHC will often make you the odd man out and that's not good when it comes to motors.
wild_maxx
Car: 90 TT pearl yellow z32
^^^ that is exactly why I switched over to the DOHC. When it comes to parts ect for the SOHC alot of it is DIY. I did 3 ka24e-t all together... when i should have really just done one DE-T.
