i have a b-13 and the fogs r not working
92-se-r
Car: 92 nissan sentra se-r
i tested the switch but its getting power even that the little light wont come onreplaced bulbs and nothing... i give up....
somebody help please
also want to make them work with low beam etc... need help
Faja
Car: 2009 Nissan Sentra
We need some more information here!!!! How are you fogs currently hooked up? Is it factory or aftermarket? Do they turn on independently or you have to have your headlights on first?
"The little light" - do you mean the LED light on the fog light switch? Check your fuses and ground wires.
92-se-r
yep the led light is not comming on...this is a factory se-r but looks like somebody already touched those wires already... they are not coming on at all... the switch has a blue wire and i dont know where is suppoust to go... ground is good, bulbs are new, fuse is good couse its new... i dismantle the switch to see if it was burned but everything looks ok... i used my tester and continuity was beeping.... so i dont know what else to do...
Faja
The blue wire is most likely your power source - try tapping the end of the wire to one of your fuses like your headlight fuse, turn your car on and see if the fogs work.
92-se-r
right now the red wire is conected to the red and i think its yellow from the switch next to it that its the intermitent lights and the blue to the other red and green from the same swith... like they are getting power from that switch... crazy....
92-se-r
i need to know another way... like where to connect that red wire from the gogs switch and that blue... where else i can connect them exactly that it doesnt couse truble
Faja
I don't know the colour scheme for that particular car. You can try downloading the repair manual from this site: the file you want is "EL.PDF"
http://www.nicoclub.com/FSM/Sentra/1994_Sentra/
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You need a relay or the fuse is blown.
92-se-r
wich fuse?
or what kind of relay?
RED_DET
Vendor
2011 Infiniti G37x
Maybe you should look in the fuse box. If its not blown, look under the hood around the battery section and there should be a box with relays in it and clearly marked which relay does what. If you are still lost at that point, then download a FSM. If you are having a hard time finding that, the link is in my signature.
ABNRML4U
Car: Nissan B13
92-se-r wrote:wich fuse?
Hey Man! I sent you a E-Mail the other day If you would respond I could come and see your B-13 sometime In Tampa,FL. It would be nice to see another B-13 around Tampa Bay area. Just check your E-mail.
92-se-r
i didnt get the emailbut u can call me if u want... my pn... 813-841-7124... nel
im just starting with the car, i bought it for $600 couse the transmission wasnt getting 5th, and some other small stuff, but i allready got a transmission, a racing cluth, new cv joints... lokking for jdm two fog bumper and side skirts.... but i still a lot to do left,,,
