evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Jan 03, 2008 3:14 pm
it's easiest and often cheapest to locate a wrecked donor and make the full swap, if you want to turbo your engine you'll need; oil pan, oil"T" and hardline, exhaust manifold, turbo, downpipe, "J" pipe, MAF, harness, ECU, injectors, distributor and shaft, fuel pump, and it's easier if you take the turbo intake manifold as well
Might sound like a lot but if you swap the whole donor it's less to deal with
Stock 180 HP, free flowing intake and exhaust with about 10 psi I'd boost will get you about 230 HP at the wheels, if you want more than that you'll need to add an intercooler
