i have a 240sx problem child
formalyDSM
Car: 1989 240 SX with An RB20
I have a 240sx fastback that dosen't seem to want to start and i was wondering if that could be a timing problem. i have checked the electrical and fuel system. is there anyone that can help me?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
yeah, i sympathize with you. I have spun bearings, bent valves, and i have five headgaskets, and four motors.... i've pretty much done it all
I/we need more info about tis starting problem, for example:
What year is it, did it run before, have you recently worked on it, or modified it, does it crank, but not turn over, have you checked compression, are you sure you have fire, etc...
so more please, sometimes these no start issues are easy to find
jm
Car: 1990 nissan 240sx
You should check to see if your timing belt is worn or broke, because if it is your engine will not crake just spin. i've had the same problem before.
