i have a $1000 to spend...what should i get?
josephg15
Car: 1992 240sx
ok so i came up on $1000...but i dont know exactly how to spend it and get the most bang for my buck.
here's what i have:1992 240sx hatchbacksr20det redtop - rebuilt T25 - ebay FMIC - 3" exhaust all the way back - greddy type rs bov - turbo xs dual stage boost controller - electric fan
i dont know wether i should get a T28...because i dont know if i need a z32 maf, of bigger injector or a chipped ecu...
i was also thinking about getting HKS 256 cams to match the T25
give me some ideas...thanks, joe
Modified by josephg15 at 4:01 PM 8/16/2007
Modified by josephg15 at 4:36 PM 8/20/2007
Fenvy
Car: 2005 350Z Base 6MT
I say a nice set of tires/wheels or coilover
turbo is nice but I would associate some head work suchs as cams, injectors, valve springs/retainers with it because tuning is needed
josephg15
Car: 1992 240sx
i want to to keep the outside all stock...sleeper...and yes i need to look into tires...but im consentrating more on the motor right now.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
You really need a UR crank Pulley!!! Hey guess what i have one for sale..
jdm180
Car: 180
depends what you are trying to do. i would definitly get a suspension if you don't have one already. it also depends on whether or not you would be installing the stuff yourself. i would personally get s14 turbine, 264 brian crower cams, bigger injectors and a rom flash. might be able to get all that done with a G. Just gotta shop around a little. i know phase2motortrend has the brian crower cams for like $300 for in and ex.
oh yeah and a z32 maf would definitly be a good idea
josephg15
Car: 1992 240sx
well this is what i was thinking...
- using my T25 and getting 256 hks cams, a nismo fpr, z32 maf, and chipping my ecu...
...i dont know if i need a z32 though if i run this set up...
jdm180
Car: 180
why get hks cams when you can get the BC ones cheaper and they are just as good IMO. i would get bigger injecters and a better fuel pump if u want to turn up the boost.
josephg15
Car: 1992 240sx
well i saw a guy on here selling his hks 256 for $310 shipped... i have a 255 walbro
usncorpsman
Car: 02 S15 Silvia
13 Ford Raptor
the last guy i talked to about brian crower cams had his snap in two in his hands...not even installed... brand new... hks atw... good price
jdm180
Car: 180
damn never seen that before.
$310 for in/ex 256 brand new HKS cams? good price!
elgarvo616
Car: 1995 240sx aka sweet thang
if youre planning on motor work, plan on upgrading the anemic t25. that will probably drain your budget tho.
my vote goes to coilovers/suspension. makes the car that mch more fun IMO
spider_slayer
Car: S14 240SX
S13 240SX
lightweight flywheel, driveshaft and then allocate the remaining 150 into something like maintiance, replacing water pump or something like that.
josephg15
Car: 1992 240sx
if i just get a t28 turbo can i put it on and boost safely without the z32 maf, bigger injectors, and a tuned ecu?
i was thinking about boosting 10-12psi....will my stock motor run better with the t28? i have a walbro 255
92SR20S13
Car: sr20det-s13
There is no tuneing required when switching to a t28.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
be careful with running the T28 w/ up boost on stock ecu. Have only seen lean conditions without the proper fuel adjustments. It run fines and feels strong but not necessarily the best bet.
I say go with Tires, and a j30 rear, and a AVCR
jdm180
Car: 180
i would agree. putting more boost without tuning is like adding more air without adding more fuel. so yeah running lean.
SRspoolin
Car: Sileighty
if you get coilovers, you can still keep the 4x4 look
josephg15
Car: 1992 240sx
im getting the sport max 962's in 18" gold...and the xenon lip...
SRspoolin
Car: Sileighty
you said you wanted it to look like a sleeper? and now your gettin wheels?
josephg15
Car: 1992 240sx
ok so i was going to get wheels but that didnt fall through...so now i think i and going to build around the t25...what is the best way to build around the t25 turbo?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Best way to build around it is to get rid of it. If you keep the boost low you are fine with installing a T28 on your SR. Save about $250 for parts to install the damn thing though.
Emperor_Tha
just rebuild your heads. get cams and valvetrain.
koukicody
Car: 93 Mazda Miata
suspension and/or tires
SRspoolin
Car: Sileighty
so its cool to run 14psi on a t25 but no more than 12psi on a t28?
josephg15
Car: 1992 240sx
so what would be better to do...boost the t28 @ 10psi or the t25 @ 12psi...whats the most i can boost the t28 with a stock motor and a walbro 255? im just going to go t28 for sure...
gripstr
Car: Street Legal s13
Dude if you dont have suspension work done....
get it done.....
coilovers ftw
Divine0425
I really wouldnt mess with a turbo right now anyways, Id do the injectors and mess with a turbo later when you have more money to spend.
josephg15
Car: 1992 240sx
well im getting 440cc injectors as we speak...
redtop91
You do realize that you'll need an ECU tune for those injectors which will run you $500.
josephg15
Car: 1992 240sx
yeah i am also getting the z32 maf and enthapy tuned ecu...is that all i need?...
