I have 91 240SX and I just replaced the distributor
Sam French
Hello I have just replaced the distributor the ECU was giving me a error code for the crank postion sensor. I am also getting a leaky injector code as well. I put the distributor in the car and I got it to where it will start right up. However it runs for about 5 seconds and slowly slows down to where it dies. I can not give the motor any gas at all it just dies when I do.
I do have the air cleaner hose from the TB to the air cleaner removed so I do have some open hoses are these what my problem is?
any help would be appreicaited.
Thanks and have a happy easter.
Sam French
I reinstalled the plastic hose from the TB to the air cleaner and reattatched the hoses this solved that problem.
Now the TPS is on the the TB opposite from where the throttle cable is.Is there a easy trick to disconnect I am worried I might break it.
Thanks
