what's the definition of ps? my search results had a lot of...static :Pnismofly wrote:actually it was 280ps, which is 276hp, but ya thats the right idea.
maybe!sideshowbob wrote:You must know nothing about investing.
wow, pal, easy there. i am way beyond in math dept. FYI, theoretical math/comp science.sideshowbob wrote: Can you add??? I mean for real, can you add??
Holy mother of God, someone with common sense DOES still exist!InsanityInc wrote:
Er... ># of cylinders doesn't mean more torque. It has more to do with the stroke, and generally a 6 cylinder of 2.0 displacement will have a lower stroke than a 4 cylinder of 2.0 displacement.
Looked it up, and yeah, the RB has a lower stroke:
RB20DET Bore:78mm Stroke: 69.7mmSR20DET Bore: 86mm Stroke: 86mm
The RB20 will be able to rev higher, but will have lower general torque at similar CFM. Also, some more digging reveals that the higher-boosting RB20 actually has less torque in stock form than the SR20 (SR20:203@4000, RB20:193@3200).
Modified by InsanityInc at 9:58 PM 11/30/2004
^^^ Sideshow is right, to double your money with a CD @ 5% interest, it would take roughly 15 years with a 35k initial investment.sideshowbob wrote: I should say.. can you multipy and divide?? Do you know how much of an interest rate you'll have to make to double your money in 5 years?? UUmm, even the average(for the last 72 years) small cap can't match that . Cds generally pay less then 5% and are very safe. Bonds pay more and are a tad riskier ( based on the grade of bond) Junk bonds pay the most. Mutual funds have a higher returnand have more risk then bonds ( same return as a junk bond). Stocks are the next step up, then ipo's, then futures.
It would still be FAR superior then putting two yrs salary into a car![s3 wrote:]
If you put your $ into a CD for 15 years, you deserve to be shot.
Yes, drug traffickingsanioll wrote:well this proves that i know very little about investing.
but there has to be an easy way to get rich. just has to be.
