Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Wed Apr 29, 2009 2:26 pm
Oh okay I didn't know the coolant passages were different my bad.
What you need to do is take the fitting off the line and put a crush washer between it and the block. Then tighten it down, but make sure not to over tighten cause a lot of people strip their blocks out doing that.
Then tighten the line onto that fitting. No washer is needed as it is a flare fitting so when you tighten it down it will spread inside and seal it.
Some people will say to use teflon tape here, but I wouldn't recomend it as these are not tapered fittings and they are flare fittings. I didn't use it and have 0 leaks.
And I think the coolant can go through either way? But don't take my word for it. Not sure which one is the feed on mine, but the one coming from the side of the block under the exhuast manifold is going into the right side of the turbo, the side you can see when it's bottom mounted on the manifold.And the inside coolant line of the turbo is going to the back of my engine.
I got that setup from looking at positrons build thread when I was putting mine together, I don't know if it's different for a s14 sr though
