mattback »
https://forums.nicoclub.com/mattback-u1350.html
Fri May 16, 2003 10:33 pm
So driving up towards country side today.
I needed a haircut at the local mall. drove up into the mall. parked. got out. haircut. chik fil a. food. yum. walk back out to car.
WT:LKJ@$)(F)*F FHQWHGADS!!?
transmission fluid everywhere except in my transmission. all over teh concrete all over anything. but no trail leading up to my parking spot....?? this is rather odd. almost as if the car overheated or something and blew out a front seal. that's waht i figured it was. called a friend. met up 2 blocks away. (that's all she had in her) from there i was able to inspect damage. couldn't really see where exactly it was coming from. still figured it was leaking form the front pump seal.
pour 3 quarts in. 1 quart empties out as im pouring it in. jesus.
limp car to shop.
inspect.
BIG FRIKKIN HOLE 1!!!!How in the hell?? I have no clue. a hole the diameter of a dime was in my transmission oil pan (auto 1989 hatchback 200bucks)So whatever. i have to pull this stuffs apart. drop the pan, clean the tarded thing off and start welding it up. Never exactly welded an oil pan before. It's not taht difficult with the tig. Thank goodness i knew how to weld, because otherwise i wouldn't have a car right now. With the oil pan now holding fluid, 6 quarts of dextron 3 (tahts all we had lyaying around) and she was back in business. total time setback: 6 hours. i had stuffs i was supposed to do today, and the stupid random thing that put a hole in my pan f'ed it all up. Oh well, it happens, nobody got hurt, except for when i burned myself finding the hole.mental note:Transmission pan temperature when hot is roughly equivalent to the temperature of the sun.
thank you, this day sucked, have a nice evening.
