go die in a fire.goofynick6 wrote:Time for an SR?
Haha, I was just making it so he couldn't give up, because of what his signature says.Kamin wrote:go die in a fire.
dont give up Carl, everyone goes through it.
yeah, kinda funny how my sig came to life and bit me in the ***.anyways im still not sure what kind of maf it is but it seems to be the same resolution as the rb stocker (car ran the same without any correction) sucks but oh well.as far as tuning possibly causing the problem, while it is wholey possible im not sure its the culprit.i always made sure that under boost the afr's were in the 11-12 range and with the chip rom it was sightly lean under initial boost (spool up) but once full boost hit it was in the 11's.again i really wont know whats going on till i leak test it so i will try and do that tommorow.goofynick6 wrote:maybe there was an underlying problem causing the tuning issues. Did you figure out what MAF you have?Nick
sorry to hear about your loss but don't give up you might have to tear it apart.. I had all my rings in good conditions but my ring glands were gone, mine also blew a lot of oil throught that vent on top pf the valve cover. good luck man just pick up another rb20 engine or keep the transmission and bolt up an rb25.Carl H wrote:yeah, kinda funny how my sig came to life and bit me in the ***.anyways im still not sure what kind of maf it is but it seems to be the same resolution as the rb stocker (car ran the same without any correction) sucks but oh well.as far as tuning possibly causing the problem, while it is wholey possible im not sure its the culprit.i always made sure that under boost the afr's were in the 11-12 range and with the chip rom it was sightly lean under initial boost (spool up) but once full boost hit it was in the 11's.again i really wont know whats going on till i leak test it so i will try and do that tommorow.
Alright man.. when mine got messed up it still rode fine as long as I didn't boost it..I didn't test it I just took it apart (I thought it was that cuz the same thing happened to my friends integra and that;s when I knew the same thing happened to me and he leak tested his and it came out fine but it wasn't when he took his apart)...I have a HKS 1.6mm metal HG from takakaira if your thinking about rebuilding it let me know.I'll work with you on it..I'm thinking of goin neo 25.Carl H wrote:ok, i did a compression test on the motor (yes i know leakdown is ideal but i couldnt find a leakdown tester).here are the results of the leakdown:with engine hot and throttle at wotdry: 145 145 145 140 140 145wet:160 160 160 155 160 165some one care to throw their thoughts out about the test results?
lyon - yeah im trying my best to keep my head up and not let this little setback get me down. and i wont swap in an rb25 too much work for little reward, not to mention i have a softspot in my heart for 2l turbo engines; specialy ones that rev to 8k.
