MS180SX »
https://forums.nicoclub.com/ms180sx-u29945.html
Wed Feb 22, 2006 6:00 pm
ok, so i try to sell my car. i put together my spare motor with brand new timing and gasket sets.. Checked everything twice like santa and all that good stuff...
I go to start it up, and it doesnt kick over right away.. Ok , so i play with the distribuor, and i get it to run and idle finee, no problems..
Now i try taking it down the road, and it runs like doo doo.. wtf
i know i had the timing right. i had new plugs put in, with correct gap..
Only thing i can think of is the 02 is really black, and should prob be replaced. ALso has an exhaust leak...
Now it runs like it is missing, and im pretty sure the plugs are fouled..
DO you think the 02 was bad, causing the plugs to foul. And if i replace them, it will work better?
IDK what could be wrong, and a very good mechanic is also stumped..He says it could be a whole bunch of things..
idk.. please give some suggestions.. I dont want to dump anymore money into this thing, its bad enough im losing as much as i am on it..
thankx in advance.
tim
