lol... every precaution listed is pretty much standard safety warnings for cleaning up glass, other then let the room air out for 5 - 10 minutes by opening a door.gmac708 wrote:And...You better take precautions if you break one.
Lamps contain mercury. Not a lot, but enough to cause some concerns on how you should clean it up and dispose of it. Here is snoops article about some myths and some facts.
http://www.snopes.com/medical/toxins/cfl.asp
EPA how to clean up after a broken lamp.
http://www.epa.gov/cfl/cflcleanup.html
MinisterofDOOM wrote: If I could work out a ventilation system I'd light my bedroom with tire fires. Out of monumental spite.
One suggestion my environmental science professor had for this was to put in one or more regular bulbs if you have a multiple light fixture. Though, I was thinking pretty much what you just said. Additionally, I've had nothing but bad luck with the Decorative CFL's that I would need for my bathroom. They have the smaller base. They don't last nearly as long as they should and they weren't as cheap as the regular ones. I did buy a 3-pack of LED decorative bulbs at Costco a month ago. I only put two in my bathroom and one in the guest bathroom. They are not offensive even when stumbling in from the dark. I would hope they will last though.PapaSmurf2k3 wrote:I've never changed a CFL out because it died. I had some DOA ones though.
I actually PREFER them in my bathroom. You stumble in in the middle of the night, flip the switch, and are gently caressed with light that slowly gets brighter and doesn't burn the living s*** out of your cornea. I seek out the slowest ones specifically for that reason.
I also tend to upgrade my 60w bulbs with 100w equivalent bulbs, and not feel bad when I get hammered and leave them on all night.
Yup! I do that in my living room where I have these s*** candella lights. The CFLs take FOREVER to spool up there, and its not in an area where I appreciate it. Once spooled up though, the 40w equivalent bulbs (which are like 9 watts or something) are actually brighter than my 40w incandescent, and by quite a bit too.C-Kwik wrote: One suggestion my environmental science professor had for this was to put in one or more regular bulbs if you have a multiple light fixture.
Encryptshun wrote:I see an ad at the bottom of this thread for an 8-watt A19 LED (50 watt equivalent) for $19.99. In big letters, it says "Lasts 20x longer than incandescent bulbs."
Um, I would pay less for 20 incandescants than your one LED, Mr. Advertiser. So how exactly is it cheaper? And I've been running high-efficiency lighting solutions in my home and seen at most a 5% price decrease in electricity versus when I ran all incandescants. Overall it's been a negative savings to operate.
I suspect there is a problem in my living room. I have a desk lamp with a touch switch. Works great in every room but the living room. I tried unplugging everything else in the room and still no go. The lamp works, but won't turn on and off like its supposed to. The only consistent way to turn it on and off is to ground a finger on the microUSB or microHDMI connector on my phone dock and touch the switch at the same time. I'll be in a new place this weekend though, so hopefully I can use it normally again soon.Dattebayo wrote:MoD,
If the CT (current transformer) on your house electricity is bad (showing more than standard 115-120 volts at the panel) or you have a corrupted sine wave, the CF bulbs seem to be more sensitive to that kind of power.
This can be different in different parts of your home depending on the length that socket is from the panel, too.
It would probably work like crap in a fridge anyways. Some new fridges come with LED arrays. Those are pretty bad a**. Some have LED's all over. Never a dark spot in the fridge. I think most if not all even bring the light up to full brightness somewhat gradually so late night fridge raids aren't so blinding.PapaSmurf2k3 wrote:Agreed. Its really all about strategic placement. If I know I'm going to be leaving a light on for a long time (garage, over the oven, etc), I go CFL. I do not, however put them inside my refrigerator.
My electric bill has dropped less than $2/month after switching to CFL and LED lighting. However, my cost to purchase and replace lights increased an average of $5/month if you factor in the initial investment and annualize versus an incandescant alternative. As Chris said, they don't like the cold, either, so my outdoor post-light, front-porch light, security lights, and garage lights should really not be CFLs even though they are right now. I guess what I should try next is to use fluorescents only where I rarely turn the lights off and LEDs where they get a lot of on/off use.C-Kwik wrote:Encryptshun wrote:I see an ad at the bottom of this thread for an 8-watt A19 LED (50 watt equivalent) for $19.99. In big letters, it says "Lasts 20x longer than incandescent bulbs."
5% is meaningless without knowing how much your actual bill is. A $50/per month bill would only save you $2.50 per month while a $200 bill would be at $10 per month. Also depends on how many bulbs you changed along with how much you use them. If you generally don't use a lot of light in your home, the savings are obviously going to much less in actual dollars per month.
breadbox wrote:I didn't read all the responses but, has anyone experineced this?
The bulb starts flickering when you touch the lamp or shake the table the lamp is on, you investigate only to find the bulb had somehow slowly unscrewed itself. I feel that they have some sort of vibration that actually causes themselves to turn. I noticed it more on upright fixtures than horizontal or upside down fixtures. although considering it unscrews itself slowly...makes me think that cfl's in upside down fixtures are potential bad things waiting to fall at you.
YES. My bathroom CFLs do that. I don't understand why or how it happens.breadbox wrote:I didn't read all the responses but, has anyone experineced this?
