I had my plugs changed at the dealer.....
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Driving Instructor
Car: 2007 nissan versa SL CVT Red
I bit the bullet. I had them done at the dealer.
$32.99 per plug and 1.3 hours later........... chaching!
But now I am good for another 165 000 kms.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Why at the dealer?
Driving Instructor
Shad0wXCalibur wrote:
Why at the dealer?
Cause I called a garage who I dealt with and they did not want to take the job. Too many stupid little things like a special socket....... I kinf of warned him and he looked into it.
For the 50 bucks I would of saved, I did go with the dealer.
NODES
Car: 2007 Nissan Versa SL (Blue)
Total cost?
I cannot believe it is $33 Per Plug...must be Gold plated
Driving Instructor
NODES wrote:Total cost?
260............bam! LOL
NODES
did you notice any difference besides in the wallet?
Driving Instructor
I would say yes. Quieter and smother..... And I kept the old plugs, they were in need to be changed!
Shad0wXCalibur
Special socket? So not as easy to DIY as other cars?
NODES
Shad0wXCalibur wrote:Special socket? So not as easy to DIY as other cars?
it requires a slim/narrow and very long socket to get in there. It is not a special tool just not an everyday type item.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Lame...another excuse for you to bring the fat Versa to the stealership for my mula.
bigdaddychia
Car: 2007 Versa 2006 Quest
it dosent require anything more than 14 mm deep well socket and a long set of needle nose pliers. Oh and removing the intake manifold. But 32 dollars a plug. the plugs are 9 bucks a peice. you got ripped.
Driving Instructor
[QUOTE=bigdaddychia]it dosent require anything more than 14 mm deep well socket and a long set of needle nose pliers. Oh and removing the intake manifold. But 32 dollars a plug. the plugs are 9 bucks a peice. you got ripped.[/QUOTE
I wont disagree that at 32 bucks per plug hurt the most but the rest I was ok with. The reason I say that that I would of had to pay alot more if I cross threaded the plug on the way in. The $130 it cost me in labour would of looked like penneys. Trust me, I am the first to look at the cost but in this case, I sucked it up and the dealer here always takes great care of me! They are worth the extra I paid for.
NODES
Next time I am passing by the dealer I am going to find out if I can bring my own in and have them do the labor part only.
bigdaddychia
Make sure the plugs are iridium. That what it uses and thats what it is designed for.
silverarrow27
NODES wrote:Next time I am passing by the dealer I am going to find out if I can bring my own in and have them do the labor part only.
I'm sure they would, just make sure you watch them install it. Dealerships are known to take the good and put in the crappy behind your back.
jwerty1
Car: 08 versa sl cvt blue, 08 frontier se 4x4 kingcab 6sp storm gray
we have customers bring in there own parts alot, no big dealmake sure you have the right plugs, i've had several issues on vehicles recently which was nothing more than some mom and pop shop put the wrong plug in, our dealer its like 11 bucks a plug, well worth it to run good without any issues, aftermarket ignition products are not good for nissans ive found, same with alternators and starters
Return to “Versa Technical Discussions”
