I had hard 3rd gear angagement and now its gone..
Nissan 350z / Nissan 370z general community discussion forum
PalmerWMD
Car: 2004 350Z
I had the dreaded hard 3rd gear engagement problem, but now after new transmission fluid (at 12,000 highway only miles), the car shifts better than ever.
I now realize, I had poor shift performance from day 1.
i just thought car was harder to shift than other cars and that it was normal for a 350.
Shifter is real smooth now, before, it had to be finessed, to go into some gears especially 3rd.
Question:
DO I have syncro problem ?
With these cars if you have a transmission problem, I understand, they usually show up a lot earlier than my current milage (13,000), but my driving is so atypical, i wouldnt be surprised if I have fewer shifts on the car than some folks with 4000 miles.I have driven entire half tankfuls in nothing but 6th Gear many times.
Also I am thinking a SC kit for the car.
DO I really wanna risk voiding my powertrain waranty when I am unsure if the transmission is sound?
But then again it shifts perfect now..
Was there any damage done from whatever the problem was before ( over or underfill at factory?)
And also worst case scenario does anhyone know how much it would cost to replace a 350Z 6 Speed, w/o the benefit of a factory warranty?
Fred...
NISTECH
labor wise it is very simple to R&R the trans on the 350, as compared to a 300z. the only caution would be the driveshaft handling since it is composite plastic. I have been told if you even bump it against something to throw it away and get a new one as it could shatter under torq when reinstalled. Cost wise the trans is $2,165.00
PalmerWMD
Car: 2004 350Z
NISTECH wrote:labor wise it is very simple to R&R the trans on the 350, as . Cost wise the trans is $2,165.00
Thats the complete transmission gears and everything?
Fred..
NISTECH
here even better and yes complete
http://www.trademotion.com/par...gid=1
PalmerWMD
Car: 2004 350Z
NISTECH wrote:here even better and yes complete
Awesome!
That mean since labor isnt a lot I should be able to get my transmission replacedcomplete for 2k, if I ever need to due to FI.
Fred.
Return to “350z / 370z Discussion”
