KADreams wrote:PDM Cams with JWT adjustable gears are good for 10-14rwhp after you tune them.
this, plus flywheel, driveshaft, and if you get that far, ITBs and headwork. The only ways to get more power from there are higher compression (sohc pistons) and higher revving with high end cams and the valves/retainers etc you`d need to run at high revvs (like 8), plus at some point, better rods to keep from bending them at really, really high revvs (like 9+). Fuel would become an issue at some point, along with timing. Heck, if you get up to that point, you`ll want a standalone or something to be much more specific on your tuning.
Course, you could always just upgrade your tires and diff, and lighten your car, and you`d be faster without increasing your power. Carbon this, aluminum that, lose weight, etc.
