I got the head off, hows it look? how do i clean the mating surface?
Cyberkreig
Car: 1993 Nissan 240SX SR
http://nissaninfiniticlub.net/...r=862
So i got it all apart, above is a link to my gallery. Some carbon buildup but in my totaly in-experienced view, its probably not too bad since i was running so rich.
Feedback?
180fan
Car: 89 fastback
don't look too bad from the ouside but looks like the engine could use some good ol fashioned elbow grease and cleaning. The top of the block you can take it to a machinist to get it decked which you should consider doing. If you go that route, just sit back and let the machinist hot tank the bugger and deck it flatter than my ex-girlfriend.
Cyberkreig
I dont have an engine hoist or any means of transporting a block.. so while i am sure you are correct i dont think that having any such work done is going to be an option currently.
Modified by Cyberkreig at 7:23 PM 4/27/2006
Dori Dori
Car: Cars of course
You blew the HG right? Bring your head to a machine shop to get planed to make sure it's not warped. Have them inspect the rest of the head. When I blew mine I spent the money on new guides, a 3-angle valve job (go with a 5-angle if you can), new seals, and a thorough cleaning. The entire cost was around $230 iirc.
To clean the block surface, take a razorblade and scrape off the old gasket. There's more than one method to prepare the mating surfaces...some people use sand paper but I used a scotchbrite pad. Once they looked good I sprayed some copper spray on both sides of the gasket and installed. Mine was a cometic HG btw. Been working well for about a year now.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
i donth think he blew the HG
looks clean....autorx must have helped out some...guess it didnt get all the carbon though
Cyberkreig
Nah i didnt blow it. i have that snapped exhaust manifold stud. the head is definatly going to the machine shop.
While is there i had planned on a cleaning and light P&P. I wanted to do the valvesprings/retainers myself, but i suppose if geting a valve job is that inexpensive i'll just have them do the 9-yards.
Id be leery of using sand paper, but you are the second person to tell me a scotchbirte pad, so thats probably how i'll be doing it.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
joe, what shop are you going to have do the work?
NightRyderNy
yah i also want to know what shop is doing the work because im in the market to get the same stuff done. thanx
spider_slayer
Car: S14 240SX
S13 240SX
when i was looking to get a valve job enjuku told me that any reptubale honda shop should be fine because the procedure is pretty close to the same.
adrianlovessilvia
Car: s14 silvia
hey whats up guys i was just woundering cause iam about to take off my head of my sr s14 and was it hard because never took off a nissan but did hondas tho but just woundering if its the same or whats some pointers ....p.s dont be a d!ck iam just asking ...thanks
spider_slayer
Car: S14 240SX
S13 240SX
pretty much the same. jsut logically remove things till you get to the head studs. you'll need a 10mm hex drive for the head studs iirc. jsut label everyhting and you'll be fine.
