evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon May 19, 2008 6:14 pm
the block and ead are correct for a 72, as for the 5 speed it's kinda tricky to identify
the carbs, assuming they are a side draft, they either have flat tops, or the sides are rounded over, the round top units are heavily favored, if they are downdrafts (which is a popular mod on cars that came with the flat tops) then they would be webber DGV's
stock distributor=points, which suck, I highly recomend upgrading to a petronix or later electronic unit
the run on issue could also be a crossed wire or 2 in the dash, behind the stereo where the fuse panel leads connect to the main harness there are several other connections, and many of them look them same, not lake modern cars that can only go together one way, you might have to get a diagram and track each wire or group of wires, lets hope it's an alt issue, I don't think the alt should be excited with the regulator off so it might be a bad alt, in which case it's a good idea to upgrade to internal regulated ZX style
