Luderacer14 wrote:Car won't start up so i'm trying to see where the plugs go, i'm thinking this might be why it won't start.
It'd help if you showed a picture of the cams from the top, so we can see the direction of the lobes. For TDC (compression stroke) on the #1 cylinder, the two intake lobes should be facing outward, and the two exhaust lobes should mirror them and face outward as well.
Here's a picture of my (very clean) cams lol.
Make sure the pointer on the front cover/oil pump also lines up perfectly with the TDC mark on the crank pulley (second one from the left)
