I got one DYNO run in today
red240ne
Car: mmm...donuts
I put down 201whp 268ft lbs, but the car died at 4200rpms, haha.
This was at 6psi from my T3/T04E 57 trim .63 a/r with A/F ratios below 10:1....haha
It's kind of a long story, but I was in the middle of my first run, and it was richer than crap, and the car eventually died out. I figured it was just b/c it was dumping WAAY too much fuel in. So I leaned it out with the SAFC and tried a couple more runs, but it was still WAAY too rich...
So, I said screw it, I'll go home and fix whatever is wrong with my car. I'm driving home, and it's barelly driveable at this point. I get out and realize that one of my charge pipes isn't even connected!!!!
So I fix that, and do a short run with my car. Another pipe blows off. Fix it, another pipe blows off....THEY WON'T STAY ON!!!
I don't know what I'm going to do...I have silicone couplers and rubber couplers. The rubber ones seem to grip better actually, and the silicones were falling off. going back to the dyno tomorrow though...
curt
WDRacing
You need some type of bead on the end of each pipe. You can use LB weld or even use a MIG welder. Both work well...I used to have the same problem a few years ago on my home made piping.
WD
ftrs13
Car: KATs
I have little weld beads on the ends of everything that connects with the connectors, so that they cannot slide off.
red240ne
Car: mmm...donuts
Yea, "klattr" was telling me the same thing, haha. I guess that's what I'll do tomorrow then!!
Thanks for the input guys..
C-Kwik
Or just find yourself better clamps(T-Bolt) and tighten them down really well.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
red240ne wrote:I put down 201whp 268ft lbs, but the car died at 4200rpms, haha.
that’s strange, most of the dyno numbers I have seen the HP numbers & TQ numbers were closer, i think the dyno is inaccurate
red240ne
Car: mmm...donuts
Like I said, I only took it up to 4200rpms..Peak HP would have been a lot higher.
Checkered-Member
red240ne wrote:Like I said, I only took it up to 4200rpms..Peak HP would have been a lot higher.
Ahh that makes sense
Def
Car: Cars, Engineering Stuffs
I've seen pipes hold together under ALOT of pressure(40+ psi, or mach 3 when released through a 0.6 in diameter nozzle) by just flaring the ends of the pipe a bit.
Or just JB Weld them one inside the other - I've trusted my life to JB Weld more times than I can remember when I worked in an aeronautical and acoustics research facility. :)
GEO
Car: 95 240sx KA-T
Beading is an AWESOME idea.
sil80drifter
Car: 1990 240SX Hatch
can one use JBWeld for beading? like a layer of jbweld on the end of the pipes, so it dries on them and sticks and makes a "bead"?
sil80
ftrs13
Car: KATs
Im pretty sure that would work, or you could just find someone with a mig welder, and put 4 beads around the pipe.
Drift Machine
Car: 1991 KA-T 240sx
C-Kwik wrote:Or just find yourself better clamps(T-Bolt) and tighten them down really well.
Thats what I did, and right now I haven't had a problem with blowing connections but I'm only running 6 psi.
Nathan
I've never blown a connector off, and thats with no REAL beads...just a few dents towards the outside I put at all the joints (hard to describe). I dont even have t-bolt clamps, just heavy duty worm gears. I dont know what you guys are doing, but mine hold just fine, even at over 25psi...weirdness.
LongIsland240
Car: 92 S13 Hatch
I thought i could get by on worm gears for a while, but the first time i blew a pipe off in traffic I went right home and ordered t-bolts. No problems since.
red240ne
Car: mmm...donuts
LongIsland240 wrote: i blew a pipe off in traffic
hahaha, yea that sucks
95_240sx
Car: My baby (car)
Dude...I will let you all in on a little secret....silicone or rubber connectors will work for this...get yourself a bottle of that real nice Aquanet Hairspray and spray it on the ends of the pipes and slide the couplers over the ends and tighten up the clamps. Remember, hairspray is sticky and it has some kind of solvent or something in it (alcohol? :) ) that reacts with the coupler and makes them stay together. I have never blown off a pipe I hairsprayed, but I have blown apart cheap silicone connectors.
Rick
GEO
Car: 95 240sx KA-T
teh WISEMAN speaks
95_240sx
Car: My baby (car)
hey as long as it works...
Rick
