I got nothing!
forksquared
Car: 91 Nissan 240SX coupe
98 Subaru Forester S (New DD)
i put in my sr wiried it and turned the key nothing. doesnt turn over fuel pump doesnt come on i dont know what is going on. the interior lights will work when i turn the key the seatbelts turn on other thant that nothing. even the window on the pass side wont go up. i dont hjave a drivers side door forgot to mention, 91 240sx with a redtop sr. the car was auto but i swaped it to manual with this engine swap and i did jump the nuetral saftey switch
highmilehatch
It's obviously not wired correctly. Try checking all the fuses first, then start troubleshooting your wiring.
forksquared
ok thanx that is what im gonig to try thursday when i have off of work... i was bummed when it happend
Modified by forksquared at 8:22 PM 5/30/2006
180fan
Car: 89 fastback
sounds like a ground.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Could it be as simple as a drained battery
180fan
Car: 89 fastback
lol ah yes the simplest answer yet...
forksquared
i just bought a new battery so i know it isnt the battery and i was thinking a ground too so i hooked my jumper cables to the intake and to thenegative of the battery and still nothing. so i guess i go fuse hunting huh? i hope it is something simple like that cuz i dont like wiring at all and idont want to go through the harness
dustyk
With all the different problems that you are having, I highyl doubt that it's a fuse. Although it's a PITA, go through all the wiring that you did and make sure you connected all the plugs back in etc. Something is really disconnected or not wired properly if your starter doesnt even turnover
forksquared
sigh.... i hate wiring...hope i can figure it out quickly
highmilehatch
You might want to take your car to someone who has experience and knows what they're doing.
forksquared
ok so i figured out it is because of my lower harness. i have an auto one and i dont have a plug that goes onto the starter. i found one that looks like it might go on but it is a different style than the one on my sr lower harness and the reason i am not using that harness is becaeseu it is butchered and i cant fix it. so looks like i need to get a 5 sp lower harness
dustyk
When I did my SR swap, I reused the KA lower harness because my SR harness was all cut up. I replaced the transmission sensors with the KA ones because the plugs were different. As for the plug for the starter being different, you can fix that one of two ways. Either cut the starter plug off of the SR lower harness and put it on your KA lower harness, or cut the plug off of the KA starter and put it onto the SR starter.
forksquared
i did cut the sr plug and put it on the ka harness and i had a bad engine ground i fixed it and it runs but now i need a new water pump it is leaking profusly
forksquared
bah i got a gas leak i dont know what to do it looks like it is from the hardlines damnit all
