i got me a new car
angel
Car: 77 chevy camaro,1985 nissan 200sx
i just got me a 1989 Nissan maxima its a 5spd 3.0 coupe what should i do to it ?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
WELCOME TO THE MAXIMA FAMILY!!!!! Y- pipe, exhaust, high flow cat, intake, suspension, look at my mods. What do you want, show car, fast car, or both? Are you more interested in looks or performance?
maxhopper
Car: 02 Maxima SE 6spd
Congrats on the 3rd gen purchase, and welcome.
angel
well what i was thinking of is putting a s15 SR20DET in it
Beancooker
Unless you want to turbocharge it, keep the 3.0L they're bulletproof. You can add the VAIS from a 5th gen to gain another 35 H.P. You may also look into a VQ35,(350Z engine) there are a lot of aftermarket parts for them.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Welcome! I've got a third gen myself.
Your 3.0 liter makes something the SR only dreams about: usable torque. Keep it. I've got 212k miles on mine and it runs beautifully.
My recommendation for a swap would be to upgrade to the 92-94 SE Maxima's VE30DE. It'll run circles around the SR, and it should be a faily straightforward swap since it was designed specifically to fit in the third gen Maxima. They've got VTC and are DOHC, and you can do a lot with them.
internetautomart
Car: more than you!
currently 94 u13 (electrical gremlin), 97 u13 (incoming)
beancooker wrote:Unless you want to turbocharge it, keep the 3.0L they're bulletproof. You can add the VAIS from a 5th gen to gain another 35 H.P. You may also look into a VQ35,(350Z engine) there are a lot of aftermarket parts for them.
The VQ is not an easy swap into a 3rd gen. it can be done, but not easily or cheaply.You can fairly easily turbo the VG30E because it was available turbo.
The VAIS is already on the VG30E in the 3rd gen.
internetautomart
Car: more than you!
MinisterofDOOM wrote:Welcome! I've got a third gen myself.
it's easier to just buy one that already has the motor. the swap is almost as complex as the VQ swap. only real difference is mounts. VE is available VQ has to be custom
Beancooker
So the 3rd gen has the VAIS and thy took it off for the 4th gen, then put it back on for the 5th gen? Something about that doesn't make sense.
internetautomart
Car: more than you!
the VG30E
beancooker wrote:So the 3rd gen has the VAIS and thy took it off for the 4th gen, then put it back on for the 5th gen? Something about that doesn't make sense.
the VG30E got a variable intake as did MANUAL transmissioned VE30DEs.the Variable intake was dropped as a cost cutting measure (one of many) for the 4th gen. the 5th gen got it back because they could get any more power out of the VQ30De without it and they needed more power to be competitive in the market.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
internetautomart wrote:it's easier to just buy one that already has the motor.
Exactly.
angel
thnx everybody i think i'll stick w/ the 3.0 and put a T28 turbo on it and do sum engine work but first i got to keep it running untill i move to east texas
