I got holes in my intecooler pipe
clutch Kick drifter
Car: 1992 Nissan 240sx/ Blacktop SR20det
Some of you may remember my sputtering problem with my SR (blacktop) . Well nothing has changed but i did find three very, very tiny holes in my right side intercooler piping after the hot pipe and JB welded them up. Then it still did it but not as quickly and bad so i found three other tiny holes in my cold pipe... Could these tiny *** holes be the cause of it sputtering at 4000 or so RPM level? THANKs
Valley
Car: 00 celica gt-s 89 240sx hatch
what is your a/f at those RPMs under load? if its going way to rich then sure. in DSMs when peeps switch to BOV and don't recirc them it happens a lot (the BOV vents metered air to atmosphere and they get a huge rich spot whenever they shift)
clutch Kick drifter
Aight what is the DSM? So what do i need to do ? Recirculate my BOV into the intake piping.. If so does blitz make a kit ?
sr20detmaybe
Car: 95 240sx
DSM stands for Diamond Star Motors which is Mitsubishi Eclipse, Eagle Talon, and Plymouth Laser.
nismostate
Car: all sorts of motorsports
you need to check for boost leak.. there shouldn't be any holes throughout your intercooler piping.
clutch Kick drifter
I think it was something with my coilpacks actually.
Nismo_Freak
Car: 89 Nissan 240SX
1. Plug all the holes in your intercooler piping. 2. Replace your spark plugs with NGK Coppers with a small gap ... 0.032" or 0.030"3. Valley is talking about something that has nothing to do with your problem. 4. Make sure your BOV isn't leaking, tighten it down until you get light surge at about 0 - 1 PSI and you should be good.
