I got egged and I need help gettin stains out...
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
yomeeeesh
Car: 2009 G37 Journey Sedan
So the title says it all basically I got egged and I washed it off scraped the egg shells off my car with my hand and all that. I tried everything from water with vinegar, detergent with warm water, and even contact solution but it's still not coming off. I was just thinking of going to the carwash or a car detailing place and asking them what I can do. Other than that...Did anyone else have a problem with this and found a better solution? Any help would be appreciated.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Try claying the surface and if that fails then try some rubbing compound. But if claying doesn't work then you need a pro to work on the paint because rubbing compound can strip paint if not careful.
joe603
Car: 2014 Durango R/T
+1 on a claybar. Wash the car with mild dishsoap to remove any wax. Next, use a spray bottle with some carwash solution and clay a section at a time. If it comes out, wax the car...if not, a pro would be the next step.
Return to “G35 and G37 Interior, Exterior and Audio”
