virus77 »
https://forums.nicoclub.com/virus77-u14925.html
Wed Jul 26, 2006 6:05 am
helicoil should be fine, since there are so many other bolts its not the only load bearing one. Or you can retap slightly bigger and use a new bolt, I dont know if this will throw off the rotating assembly or not though, I doubt it but its something to consider.
Also if the threads are slightly screwed you might get away with using a thread chaser and saving those threads.
