what impresses my buddys and people that sit in my truk wen i crank it is how their ears hurt like a mofo wen they get out, lol. i love my music with that pounding bass, its something not alot of people care for but its my truk nd my music nd its how i like it! lolQxxx4 wrote:Nala, nice setup! your going to experience every song in a whole new way. I cant stand hearing music in stock systems now, i end up laughing at my friends.
Natedogg, you have the same taillights as me!
as for the installing yourself...its so true....I got my subs/amp/box for $140 used of craigslist, still pumpin hard a year later, and if the setup gets stolen...wow..$140. Sure its not a sick setup like natedoggs, but i get a real clean sound that my friends all find impressive. (2 10" clarions in a sealed box, """"1500W""" (super quotations) boss amp that im shocked hasnt died.) The pride i get that i did it myself is immense, its not worth it to pay someone else, it was so much damn fun figuring it all out and it really wasnt hard at all.
The size of the LED should depend on where its going. I suggest not going bigger than 5mm or you might not be able to fit the LED where it needs to go, If your having trouble trying to spread the light sand the top of the LED to get a wider angle of light.Natedogg1701 wrote:so you have those tails too, nice. how does the reverse lights work for the Q? i thought they were next to the lescence plate. and in that pic they are slightly tinted, im going to tint them waay darker just havent gotten around to it yet. i actually just got most of my blue interior conversion done, im lovin it and everyone that sees it thinks its cool 2, only things left are the defrost button and the door lock and window switches, curious tho, radio shack offer 2 types of blue led's, which ones should i get?!
WRONG!!!fueler wrote:you blow subs by underpowering them... that means trying to make them wang when you dont have the power, they will clip / distort and eventually blow. or if you have them wired wrong, or setup for the wrong ohms.....
Nala... LMAO... That amp puts out like 200 watts...naladude911 wrote:Lanzar 1000w amp
Please stop talking...Natedogg1701 wrote:and finally, yes most subs are blown because they are underpowered, when a sub is underpowered it doesnt hit straight forward and backward, it will twist and warp, this is because the entire magnet isnt being energised enough so the voice coil isnt getting equal magnetic power all the way around.so the sub twists as it plays, the spiders and surrounds wear out, and sometimes the voice coils will hit the inside of the magnets a,d wear down, break, or short out.
Wow... Just wow...Natedogg1701 wrote:sony isnt lying about the 1000 watt claim, they arent just explaining at all when the amp will make that power. one its with a perfect 14.6 volts constantly at the amp, and its not at the low sub playing frequencys that most people who buy them use them for, it requires more work for an amp to play a lower frequency, the 1000 watt claim is under whatever sony considers PERFECT conditions, and at a higher frequency. so technically they are not lying, but they still sukk none the less. lol
My crappy system employs focal components with TC sound subs. Using Hifonics Zeus and Thor amplifiers, and an Alpine HU.fueler wrote:why do i get the feeling that this Q45 guy either has no system or a very crappy system ?
naladude911 wrote:Here is the amp:http://www.lanzar.com/itempage.asp?MODEL=VIBE241
After looking at my amp again, the audio place set the amp at "low". Is it safe to set the amp at high?
That amplifier uses two 15amp fuses. That's a total of 30amps maximum. To get wattage you multiply volts x amps. Use 30 x 14.4 = 432 watts. That is the MAXIMUM DRAW that the amp can have, not output.fueler wrote:your amp is 500w rms (250 per channel) so it is matched perfectly to your amp.
This made me laugh. Really hard.naladude911 wrote:...and smiles from the ladies
That's nice... Hifonics have a decent rep. So I don't know what you're getting at.Natedogg1701 wrote:ok poormanG45, first id love 4 u to sit in my truk so i can blow your ear drums out, second you use hifonics amps.......im sorry.
For pure sound quality paper or cellulose materials are still the best. You have a different goal in mind. You want skull crushing SPL. I want it loud enough to drown out the surrounding noise and still sound excellent. For this, paper is the way to go.http://www.mother-of-tone.com/speaker.htmNatedogg1701 wrote:...if your subs have the wire wrapped around a cardboard tube then they must sukk, again sorry for you, get decent subs that have like mine a hard plastic tube.
Wrong! No matter the power, 1 watt or 1000 watts, the EM field generated by the coil is designed to maintain the same shape to maximize efficient interaction with the magnetic field from the magnet.Natedogg1701 wrote:and yes moron i know current flows through the entire coil, but a weak amp will not push full current through the coil, you get a voltage drop, which weakens the em field created by the current through the coil which makes it not move straigh forward and backward within the magnets, it twists,
By "cranking up" the amp you are simply supplying more power. This will cause the cone to travel farther then with less power. It will still travel in a linear path until linear Xmax is reached. If you exceed this rating then the interaction with the magnetic field will be more erratic then when traveling within linear specs.Natedogg1701 wrote:so when you crank up that amp not only are you getting that square wave which does not cool the sub enough, it causes the twisting action to become more severe and wears out part quicker along with the heat.
You don't read do you. That amplifier will NEVER put out 1kw. I'm referring to the amp Nala posted that has 2 15amp fuses. The ONLY way for it to put out more then 432 watts is if a short circuit occurs internally and the power is directed to the driver.Natedogg1701 wrote:and the sony amp thing, how bout u just go jump off a cliff, i know its a maxpower rating, but do the experiment yourself,hook tha mp up and change the impedances to it and the frequencys your having it push out, provide different voltages to the amp, and figure out the power coming out of the amp.
