not vacuum!!!!
part of the coolant/heater system runs through the throttlebody to help keep it from freezing closed in cold weather / whatever.
You really need to look at the FSM etc on how this all hooks up..
props for the spark plug plug tho
Click for water hose & piping..
also see sections 144. 214 and 278 (you'll see it mentioned in the diagram)..
keep in mind these are JDM so if you're LHD you won't be having the pipes crossing behind the engine, but instead going straight back-ish.
