whiterps13 »
https://forums.nicoclub.com/whiterps13-u9007.html
Fri Aug 25, 2006 3:44 pm
Well Im not really the one to talk, look at my wheels. However, the reason people worry about wheel weight is cintrifigul force. When a wheel spins, physics mulitply the weight by some factor due to rotational mass. Adding 1 pound to a wheel would equal adding many more pounds to the car (I have no clue about the actual relationship). I understand the concept, but maybe someone with more knowledge can elaborate with more details, like actual numbers.
Another factor to consider is overall tire circumference, which can easily throw your gear ratios out of wack. A taller tire effectively changes your gear ratios, as would a smaller tire. Again, someone with more knowledge will need to give you some real time numbers.
