evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Dec 25, 2006 7:52 pm
could also be a bad sender, this is a problem on older Z's the oil gauge sender becomes very non-linear and shows ) at idle and one over 30 psi or so it starts working, might be worth replacing the sender, unless you engine is ticking like crazy, in which case your oil pump is dead and youre engine could blow up at any time, lets hope it's just the sender
and you did check your oil level and your filter isn't unscrewed...right
