dc1984 »
https://forums.nicoclub.com/dc1984-u34446.html
Mon Apr 13, 2009 10:07 pm
i believe that the three to four ports available near the throttle body are as vacuum as they come. they all represent manifild pressure. when the car is under boost, they are a boost source, when its under vacuum, they are a vacuum source. thats exactly what u need to have hooked up to ur BOV.
the problem is thqat some people hook it up before that.sometimes, when people have there bov mounted on the hot side of there intercooler piping, they will just tee into the wastegate actuator line instead of running a vacuum source from the other side of the engine. that is obviously completly wrong because that line that goes to the wastegate actuator only has boost, no vacuum at all. and without the vacuum, the bov wont open. im not saying this is the problem, i just want to make sure its not as some people who are fairly new to turbos dont understand this too well.
what kind of a bov do u have justin. i know the blitz DD bov has two different springs that can be put inside. one is soft and one is stiff, for higher boost apps. u might want to look into that possibility.
