waynegarcia13 »
https://forums.nicoclub.com/waynegarcia13-u163293.html
Wed Sep 29, 2010 12:14 am
A vacuum leak is possible but not the injectors they rarely go bad.$10 says it's the MAF sensor.Do you have a scanner? That sounds a whole lot like you have a bad Mass air flow sensor to me. If you don't have a scanner go hire a mechanic that does to do a diagnostic on it but make sure he has a REAL scanner not a cheap code reader there is a BIG difference. A diagnostic should only cost around $50+/- I don't know where your from but here in San Antonio there are a lot of mobile mechanics "i am one of them". I am sure there are some in your area, look on Craigslist in the automotive services section and you will see ads from mobile auto repair mechanics. Have you tested fuel pressure, spark from the distributor while the truck is running and stalling, is there an engine light on? You will find the problem if you go down the list: spark, fuel, compression, timing. Like i said if i was you i would definitely check the MAF sensor, with a scanner you can check it in 10 seconds. Give us a little more info. on what you have actually checked and tested don't just change parts out until you get it right that could take forever. For all of that money you spent on parts you didn't need you could of hired a mechanic to do a diagnostic, just find a guy with a matco, snap-on scanner, auto xray or mac scanner.
