I Give Up!!! Need Help!!!
rs12
Car: 1985 RS12 Silvia CA18DET
Ok i got the motor in the car a couple months ago and got it running good. After about a week it started to start hard and rough and i had to keep throttle to it but once warm it ran fine (This is with the cold start signal hooked up) it began to get worse day by day. Than a couple weeks ago i drove it around the block and i popped a charge pipe off so i limped it back to the house. The next morning i came out to start it and it started than died and would only crank from there on in. Now i have power to the injectors and the plugs and i have checked the resistance on all of these as well with good results. When i crank it the plugs are soaked with fuel (all but one). If i take out the fuel pump fuse and spray in some quick start it will start and run but only off of the quick start! I dont know what else to check now!!!! Im highly confused!! Any help is greatly appreciated!!!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
first off, i would check the injector in the cylinder that is dry. not that it will solve your problem but it sounds like another problem waiting to happen. check the coolant temp sensor, aicv, etc. im a little hammered right now but when i sober up im sure i can be of more help.
tyrannix
Car: go big or go home
r34 gtr wrote:first off, i would check the injector in the cylinder that is dry. not that it will solve your problem but it sounds like another problem waiting to happen. check the coolant temp sensor, aicv, etc. im a little hammered right now but when i sober up im sure i can be of more help.
nico while drunk?
nerd
r34 gtr
well, my computer happens to be in my living room, so i was taking shots and the forum just happened to be up. plus nico owns, im sure youll agree. nico doesnt jusdge me while im drunk!! (judging time?)
float_6969
I still love you Tim, even if you are a social outcast!
