Ya the larger injectors are definatly on the list of things to buy in the future, was just hoping to be able run the car on these for a while till I can afford new ones.. I will try to get around to testing the injectors this weekend, but being the utah supercar grandprix is this weekend might be kind of busy!
So here's where I'm at now, been messing with all the plugs just cleaning things and making sure they're working, also deleted my ptu sub harness which actually definatly helped the lower rpms..
Right now the car starts right up and runs strong in the bottom, here's what I noticed that I didn't before. I can get on the throttle and the car starts to sputter as soon as i start to boost, thats why it's a little different depending on what gear I'm in. But my boost gauge comes up right to the 0 then it sputters like I'm hitting a Rev limiter. Also i can smell lots of fuel in the air when it starts to sputter, and sometimes it'll backfire when I shift out of the sputtering, which not gonna lie, brings a smirk to my face lol.
I can down shift when im going faster and itll put the revs up at 5k and as soon as i try to give it any gas at those in rpms it sputters and won't do anything till it slows down more.. Even though it says it builds boost right to the zero I can hear the waste gates whistle on the turbo when I shift, especially in first gear. I'll retest all the things on the list budget300 listed, i imagine some will be different with all the new clean connectors.. Also still need to test the tps! thats the one I keep forgetting to check. Thanks for all the help guys
