Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Thu Dec 08, 2005 4:10 pm
No problem, if you decide to get rid of it, I might want to take a crack at the R&P. I installed my own LSD and even though contact looked on center, it may not be. If it shears off, I will need another Ring and Pinion. If you decide not to, try a Phantom Grip. I hear good things about them, and they are affordable and easy to install. When you put the VLSD in the non-VLSD housing, the passenger output shaft sticks out a little from the housing. Not so much as to cause a leak, it just looks weird. There is your second clue. This is because it cannot be installed (so that it will lock) without a longer input shaft on the passenger side. Otherwise, the shaft would not reach the Viscous Coupler. What's worse, is that it would not snap and lock in place, and the diff would leak like crazy. Hope that helps.
