Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon Sep 01, 2003 11:55 am
rbsileighty, did you check the pdf I posted? The F3 connector is the one you mentioned, the big white one. Maybe I was not clear about the ECU and injector power wiring...
On the KA, the ECU and ECCS relay are powered through a 7.5A fuse directly from the battery. The injectors and coil are powered through a 30A fuse through the ignition switch. Thus the ECU always has power (so it can do stuff like run the carbon canister purge, start the fuel pump a split second early, etc.). But the injectors and coil are powered up after the ignition switch is turned on. So the ECU power runs through F3(pin 17, red), and the injector/coil power runs through F3(pin 1, black/red).
On the RB, the ECU, ECCS relay, ignition coil relay, and injectors are all powered directly from the battery through 25A and 30A fuses. Although it may be necessary to power the ECU even when the engine is off, it is definitely not necessary to power the injectors and coil. Plus, if you try to use the KA wire that goes straight to the batter, you only have a 7.5A fuse! On the other hand, if you run the whole RB power off of the 30A fuse, the ECU will never have power when the ignition switch is off.
What I plan to do is to separate the ECU and ECCS relay wire from the injector power wire. I will run the ECU/ECCS relay wire as it is on the KA, thru the 7.5A fuse. The injectors and coil will run through the ignition switch and 30A fuse (the big black/red wire on the F3 plug). That way the ECU can have power when the ignition is off, and the injectors and coils can still have the benefit of a 30A fuse and heavier gauge wire.
I would also like to know how well Hybrid's DP hold up with time. It would be cool to use the stock turbine flange, but I do not trust welding mild steel to cast iron. I bought some 1/2" mild steel bar and 3" pipe to make up a new flange/DP. Now I need to find somewhere to get a bung for the O2 sensor.
Shane
