I found the problem for loss of power in our cars!
s13rb25det
Car: 92 240sx w/rb25det
o.k. my s13 has been giving me trouble with intermitent loss of power at low rpms. I checked everything and it seemed to be o.k. untill I checked the fuel pump voltage and it was all crazy 5-9 and them back to 12 volts so I got a fuel pump from ebay and through it in and ta da!! it fixed it. I read that a lot of fuel pumps are going out because of the ethonol thats being put into fuel so if your car is going crazy mostly at low rpms and on hot days just get a $30 ebay fuel pump and try it. I hope this will help some people with this stupid problem.
ZOMG.SR20
Car: 1990 s13
sweet im going to o this cause i tested the voltage in my harness and found that so im a try this except with a walbro
AZ89two4Tsx
You're not always going to be right, lol.
The problem with mine was my battery terminals.
DroptopDrifting
Car: 94 240sx limited edition se convertible
how are those ebay pumps? are they actually somewhat decent?
roadboy240sx
Car: I like Nissans
maybee my problem too ?
s13rb25det
yeah I know it could be other problems but im pretty sure this is the problem most of the time. the ebay pump was really good quailty it came with all the wiring and every thing like that I got about 200 miles on it and no problems yet.
Artigo
Car: 1993 240sx coupe SR20
Why not just get a walbro?
DroptopDrifting
its a $70 difference. ebay is $30 and walbro is $99 from frsportanyone know how much an oem one is? probably somewhere in between those. and walbro has a shorter lifespan than the oem one. have you seen the smallness of the walbro? theres a few reasons to go ebay instead of walbro. only put the walbro in if you need to, if you ask me.
DroptopDrifting
did you get the pump from "Radiator Guys" on there? did it come with a filter too? in the pic i dont see one....
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
DroptopDrifting wrote:its a $70 difference. ebay is $30 and walbro is $99 from frsportanyone know how much an oem one is? probably somewhere in between those. and walbro has a shorter lifespan than the oem one. have you seen the smallness of the walbro? theres a few reasons to go ebay instead of walbro. only put the walbro in if you need to, if you ask me.
That is really the worst display of misinformation I have ever seen. Where do you get that the Walbro isnt gonna last???? I had one in my 240 for 6 years and never one issue. The "smallness" of it. It doesnt need to be any bigger, it still has to fit in the sending unit...
And what are the "few reasons" to go with the ebay one... The "smallness" has nothing to do with its performance, and the life span of it, it'll last a hell of alot longer than a cheap ebay knock off version of it. I am all for saving money, but this is something I wouldnt cheap out on. Walbro has made a name for themselves in imports and have been around for a long time. Now what you have said is childish, and inexperienced. I ran a walbro 255 pump in my first civic for 10 years. You drifting that drop top and beating the hell out of it. The fuel pump will outlast the car... The ebay one, you'll be spending that money again later to get a walbro.
Modified by blacksrjdm at 10:37 AM 7/6/2009
ray666
Car: '92 240 sr powered tuned with a neo
Let me try to sum up what the guy above me typed. Just spend the 90 bones in a reliable part and be done with it.
igovr00m
Car: 1995 240sx se
i never will understand why people rather cheap out and buy the knock off versions... a few months later they will make a new thread saying "NEVER BUY FROM BLAH BLAH MY THINGS BROKE" just spend the extra 60 dollars or w/e and buy a REAL dependable part.
do it right the first time
Jadesr20det
Car: 1990 NISSAN 240SX
"Cut corners and you end up in a circle"
cracka400
Car: 1998 Nissan 240sx, 1989 240sx Coupe, and 2011 Nissan Versa HB
I might have to try this also. It seems that this is the last thing that I haven't tested and or fixed.
240dx
Car: '97 Nissan 240SX LE
What exactly do you mean when you say your "Car goes crazy at low RPM's"
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
ebay fuel pump... maybe if you got a beater 240
DroptopDrifting
i had a walbro, lasted a little over 1 year in my car, maybe close to 2 years. from my experience, they don't last as long as oem. and what i was saying is why spend the $90 on a walbro if i dont have any reason for more liters per hour. im not goin turbo, nor doing any tuning. i'd rather get something cheap for now and inexpensive to last me til i do decide to add power. i wasnt saying at all that walbro isn't good or anything like that. they make a good pump for what it is. but in no way are they the best and i dont know how you got 10 years out of one, that's unheard of. even 6 years is pretty crazy. anyone i know that's used a walbro pump has never had it last that long. for now, i'd rather spend the $60 on an oem one. i was just curious as to how the ebay ones are since it's a pretty simple piece of machinery. and im more curious to see if the filter comes with the $30 pump so i can buy the set, and resell the pump itself for $20. it's good to have backup filters and for $10 you can't beat that. i love how you are always so quick to jump on others asses. relax guy
DroptopDrifting
igovr00m wrote:i never will understand why people rather cheap out and buy the knock off versions... a few months later they will make a new thread saying "NEVER BUY FROM BLAH BLAH MY THINGS BROKE" just spend the extra 60 dollars or w/e and buy a REAL dependable part.
do you understand how a fuel pump works? not a difficult thing. some stuff you can get off ebay, i.e. intakes, and they're perfectly fine. other things, like turbos, you dont buy on ebay. you just have to think about the design, how elaborate the item is, how difficult it may be to be precise when making it, etc. the fuel pump doesnt seem too crazy so i figured i'd enquire about it. oh, and if you're lookin for REAL dependable, i wouldn't even bother changing anything from stock.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
s13rb25det wrote:o.k. my s13 has been giving me trouble with intermitent loss of power at low rpms. I checked everything and it seemed to be o.k. untill I checked the fuel pump voltage and it was all crazy 5-9 and them back to 12 volts so I got a fuel pump from ebay and through it in and ta da!! it fixed it. I read that a lot of fuel pumps are going out because of the ethonol thats being put into fuel so if your car is going crazy mostly at low rpms and on hot days just get a $30 ebay fuel pump and try it. I hope this will help some people with this stupid problem.
if you have 5-9 volts at your fuel pump, then you put a new one in, you would STILL have 5-9 volts at the pump. sooooo, exactly how did this "fix the loss of power"? only thing that makes sense is mabe you cleaned up the connections accidentaly or mabe the placebo affect
wackawacka
Yes, Listen to the guy who found the problem with the power loss in "are" cars.
jr_ss
Car: 95' S14
DroptopDrifting wrote:if you're lookin for REAL dependable, i wouldn't even bother changing anything from stock.
This line right here sums it all up, you're an IDIOT....
Stock fuel pumps cannot flow enough fuel in a swapped car, hence the reason to UPGRADE, to something better. And by better, I don't mean a $30 piece of sh*t off ebay. Spend your money wisely or send it to me, my paypal address is [email protected], Thanks in advance.
If I were to do it over again, I'd spend the money and get the Tomei FP, plug n' play FTW.
maryjane
have had a walbro in my ef track car for 4 years now and twin walbros in my s13 going on 3 years, never say your car has the same problems mine dose ie fuel pump voltage, have fun with your ebay pump, ill spend the extra 60 and buy a walbro.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
what is it with stupid threads.....
I hate NICO sometimes
igovr00m
Car: 1995 240sx se
ROFL, drop ur a fkin moron man, just delete ur forum account or something
ZOMG.SR20
Car: 1990 s13
the ethanol dries out seals in fuel pump hence the reason for failure in most.....your civic that had the walbro in it probably was from a time that didnt see alot of ethanol
DroptopDrifting
what is wrong with you people and the personal attacks? grow up. this is a forum, not a nursery.
igovr00m wrote:ROFL, drop ur a fkin moron man, just delete ur forum account or something
you have no idea what you are talking about and couldn't be anymore childish.
maryjane wrote:have had a walbro in my ef track car for 4 years now and twin walbros in my s13 going on 3 years, never say your car has the same problems mine dose ie fuel pump voltage, have fun with your ebay pump, ill spend the extra 60 and buy a walbro.
yes, if i had a highly modified car, i'd use a more efficient pump as well. but that wasn't what i was talking about before, these ***holes just decided to twist things around to bring it to this.i totally agree, if i needed the pump, i would get it.
you need to grow up. to make personal attacks on here is just pure immaturity. i never said i was getting the fuel pump from ebay, i was asking if it came with the filter so i had a way to get a cheap replacement filter. maybe you should read what i actually wrote before you make your comments. i wrote that if you wanted "dependable" that you shouldn't modify your car in any way. where in there did i say "do not upgrade your fuel pump if you do a swap or modify your car." please learn to read before you comment on what others wrote. calling me an idiot like that just makes yourself look even worse in the eyes of most of us on here.
i will give you the benefit of doubt that you did just misunderstand what i was saying when i sarcastically said not to modify if you want dependable. it seems like you interpreted as me saying not to change just the fuel pump. im not sure why anyone would ever assume that, as it makes no sense whatsoever, but i was jokingly saying not to modify your car in any way from stock form if you want dependable.
Koshin wrote:what is it with stupid threads.....
im in total agreement with you.
when it comes down to it. if you are not in need of a higher liter per hour pump and need a replacement, i would rather spend the $60 on an oem than $100 on a walbro. THAT was my original argument for all you illiterate lazy people that won't scroll up and attempt to read what i wrote. i am really only interested in the ebay one for the filter since it would be cheaper to buy that setup and resell the actual pump than buy an actual replacement filter. i was just curious as to how the ebay pump was working out for the OP, so i asked. didn't think it was such a horrible thing to ask how a certain aftermarket part was working out for someone. god forbid we do that on a car forum.
Modified by DroptopDrifting at 9:35 PM 7/6/2009
Electricit
Car: 93 Mazda Rx7
94 Mazda Rx7
Wc240 wrote:if you have 5-9 volts at your fuel pump, then you put a new one in, you would STILL have 5-9 volts at the pump. sooooo, exactly how did this "fix the loss of power"? only thing that makes sense is mabe you cleaned up the connections accidentaly or mabe the placebo affect
a good point. anyone actually know what their talking about know how to reset the volts?
Wc240
97 Nissan 200SX
06 Scion xB
besides redoing the wiring and cleaning up connections, you can hard wire a relay in. there was a article on it somewhere if you need it, but havent personally done it
Wc240
97 Nissan 200SX
06 Scion xB
to droptop,
when you buy oem or oem replacement(like napa), it comes with the filter. just a friendly heads up
jr_ss
Car: 95' S14
s13rb25det wrote:so I got a fuel pump from ebay and through it in and ta da!! it fixed it.
I'm sorry you said you weren't getting an Ebay fuel pump...?
You're back pedaling trying to save your image on here, but you've already screwed yourself. Stop, admit you're an idiot for buying an Ebay fuel pump and move on.
Calling me illiterate is no different than me calling you an idiot, it is still a personal attack. But, unlike you, I don't take offense to it, because it's a forum and people are going to post stupid things. Especially this posts like this "I found the problem for loss of power in are cars". Perhaps you should take more "engrish" classes man?
I simply stated a personal opinion based on your moronic posts.
