I found a hot tank in my kitchen!?
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
Helping my buddy/roommate build his SR for his B13 sentra and discovered I have a hot tank in my kitchen.
boost_boy
Seriously..... :lolling:
s13drifter88
Hell yeah man, works like a charm. Just use an extra 1/2 cup of detergent and the inside of the dishwasher will be spotless afterwards as well.
TheMAN
I wouldn't even dare try if it was an iron block (CA18)
s13drifter88
It does VG's ok! lol
mdb4879
Car: 1987 Nissan Pulsar SE (CA18DET)
1990 Nissan 240SX (KA24E)
1995 Acura Integra GSR
I don't see a problem with doing iron blocks in particular, just wipe them down with an oily rag when you get done. My fear would be residual detergents contaminating your oil on start up. If it were me, I'd still get it hot tanked at a machine shop afterward, but this is good to make it look new again (the solvents at the shop I go to aren't very strong I guess. My E16 block was clean when I got it, but it still looked nasty)
Btw, we don't have them in our CAs, but do you think that would damage bearings? Like the jackshaft bearings in an E16 or cam bearings?
s13drifter88
Nope, pressure wash it afterwards for an extra rinse and then spray all surfaces down with wd40 or pb blaster on all surfaces. Helps to let it sit in the sun for a little while too
TheMAN
mdb4879 wrote:I don't see a problem with doing iron blocks in particular, just wipe them down with an oily rag when you get done. My fear would be residual detergents contaminating your oil on start up. If it were me, I'd still get it hot tanked at a machine shop afterward, but this is good to make it look new again (the solvents at the shop I go to aren't very strong I guess. My E16 block was clean when I got it, but it still looked nasty)
the problem is the rust that you'll get INSIDE the block... I just worked on a mild steel bracket yesterday... after some cutting and grinding, I cooled it with some water... in just a few hours, there was surface rust on it!
if I got a pristine CA block, I wouldn't want it anywhere near a dish washer!
s13drifter88
And then you plug in your air compressor and attach thy air nozzle, then witchcraft and unicorn horns, then dryness occurs... strange
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
I think I'd break my dishwasher if I did that...lol.
themadscientist
s13drifter88 wrote:And then you plug in your air compressor and attach thy air nozzle, then witchcraft and unicorn horns, then dryness occurs... strange
Not if you don't have an air-water seperator in the line. ;)
s13drifter88
Just hold a towel in front of the air stream... I promise it'll get all the water out lol
themadscientist
GENIUS! :crazy:
s13drifter88
That's how you towel dry air lol
themadscientist
I think the important concern is, what are you doing helping an SR20 owner? BOO THIS MAN!
s13drifter88
He's my roommate and taking him to and from work everyday, while he is my best friend also, gets old and interupts my drinking till late at night and what I do to his cousin between the sheets.
themadscientist
I see the SR is not the only cylinder getting bored out, nice! The judges say "acceptable compromise!"
s13drifter88
Sometimes you gotta think with your dipstick
datso
Car: datsun 1000
after dishwasher just mix 1 part molasses (sugar) with 10 litres of water leave block in there for a couple of weeks and all the rust within should be gone. Pressure wash later and hot tank for final clean aftr all rust is gone.
