dash wrote:As I mentioned in another thread my daily driver makes 472whp and 640nm at the wheels and that's on 1000cc injectors... on E85 ...on a little GT2871.
so that's not your monster ca21 build. What's the details on this one? No build thread?
ca18? cams? t2 manifold... stock? ext wg? stock intake? built block/comp ratio? ported head? ecu?
No its actually an SR ( I tried to leave that part out so I did not get kickbanned from this section)
Stock cams, stock bolts, forged bottom and somewhere between 9 and 10:1 compression ratio.
Reinforced block (not sleeved).
Stock untouched manifold, GT2871R at 2 bar boost.
1000cc ID injectors.
Nistune.
Z32 gearbox modified as described iin another thread.
I have made similar power on CA also, and I am not a big SR fan anyways.
The diesel block CA will hopefull make more power, the turbo I'm using on that is a little bigger and should handle at least 3 bar of boost .
