Slow down there chief, lets get some facts straight before you start droppin names.nyamping wrote:So I got this ECU with number 23710 80F00, which suggests an S14 ECU. But the pinout is like 9/8/7/8, which is for an S13?
Could anyone help me with this? I can't believe they gave me wrong ECU.
Also the MAF air is also wrong 22680 40F00, which is for the 240sx SOHC.
Sorry. I know I was too emotional. It's been a roller coaster month, really. You're just what I need, please help me and be my judge. Thanks. I included a couple of pictures on the ECU.Nismo_Freak wrote:
What are the letters on the ECU.
The Maf from the SOHC KA24 will work with the SR20nyamping wrote:Also the MAF air is also wrong 22680 40F00, which is for the 240sx SOHC.
Thank you speed, I dont have the engine yet, it will be here Monday. The ECU, MAF and harness are shipped from the shop. The engine is now on its route from Canada.karmakaze wrote:
the maf from a SOHC wont work on a S14 SR, you have to use a s14 zenki MAF if that is what yr your motor is, judging by that ecu ur motor is a Kouki model which uses a s14 kouki\s15 mafkarmakaze wrote:
Thanks dude. Is the S14 Zenki and Kouki MAF interchangeable? Will S14 Zenki MAF works with my kouki ECU?WhiteKoukiS14 wrote:
Dude I finally got my engine, it was drop shipped from Engine Land through Zerolift. But it is the zenki one (by the harness serial number). The engine also has gunk (oil plus sand/dust) build up on the engine block wall facing the front, to the left of the A/C compressor.SpeedRacer1 wrote:The zenki and kouki MAFS are interchangable but the plugs are different. They will give off the same voltage.
Crap on the front of the engine is not a sign of a blown block. The block can gather a ton of junk over the years. Best case scenario is that the engine is just dirty. Likely scenario the is that the front main seal or valve cover gasket needs to be replaced.nyamping wrote:
Question numero uno, does it means I have a leaky engine block (holes somewhere in the block)? It also got HKS boost solenoid, divorced dump pipe and downpipe (hint of abuse).
can I use Kouki ECU and harness with Zenki Engine?
Lmao. Yeah.... my grandma drifts once in a while.... lol, I got a stomach ache when I read it. hahahaha.SpeedRacer1 wrote:
Unless you see a connecting rod hanging out the side of the engine, the engine is still good.
Most engines that come to the US have at least some mods. Abuse is almost a given unless a 100 year old Japanese grandma owned the car before it was shipped to the US. Abuse isnt a big issue if the engine isnt already blown or has an internal issue.
If you have a matching ECU and harness you can use them on an S14 SR20DET of any year.
check your harness and ecu, if they arent correct then your gonna need another ECU or another harness, s14 harnesses are hard to come by and very expensive, you can catch a ECU on ebay every once in a while, I do have a extra zenki ECU that works perfectly, but I will prob only get rid of it for the right price as i was going to use it for rom tuning...nyamping wrote:
Thanks. I'm looking at the FSM now. Looks pretty straight forward. Any chance that the gunk comes from the front cover with bad gasket? I think removing the oil pump is too overwhelming for me...gotta deal with the timing chain and stuff.SpeedRacer1 wrote:The seal is fairly easy to replace. With the right tools its probably a 20 minute job when the engine is out of the car.
The steps are:Take off crank pulley. Pry out old seal. Put in new one facing proper direction. Install crank pulley.
Taking off the pulley is the hardest part without air tools. Just use a couple flatheads to shimmy off the crank pulley.
No so at all, 9 out of 10 engines we get are completely unmodified and still have the stock clutch and turbo. It seems a lot of owners in Japan DO leave them unmodified - and hopefully not abused.SpeedRacer1 wrote:Most engines that come to the US have at least some mods. Abuse is almost a given unless a 100 year old Japanese grandma owned the car before it was shipped to the US.
Welcome to NICO. Unlike most new guys, you've obviously found the search feature. Unfortunately, this thread is from 2005. The OP will most likely not see or respond to this. If you check the FAQ, you should find all of the stuff you need as far as identifying what parts you have.keaning wrote:can i get pics of that ecu? because i got whats supposed to be a kouki sr20det and kouki ecu but i need to make sure its the right ecu, and theres no NA or WC or any numbers on it. but the wiring harness that came with the motor is the same as the kouki harness i ordered from wiringspecialties(wire colors leading to pins in ecu) so im assuming its right but i still need to know
Go to the forum, and click "New Topic"keaning wrote:Thanks. Also how do you post threads? I can't figure it out for any forum. A bit off topic
