I finally got everything i think? is this a good set up so far?
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
Ok i got a 1990 coupe black w/ a silvia front megan coils n 2.5inch custom exhaust but i will b switching to the apexi n1 evo soon. Ive been stacking parts for quite some time now im finally onto savin for my s13 sr blacktop i will b picking that up pretty soon. Heres wut i got so far tell me if this is a good set up i still plan on gettin more goodies but i want to get the motor so heres the list i would like to kno u guys opinions and advice would help too.
j30 vlsdmr turbo manimr turbo elbowblitz 3" down pipemr test pipe2.5 inch (but gettin an apexi n1)hallman pro mbcgreddy rs bover spec hot pipegreddy m-spec fmicACT stage 2 clutch i think ( holds 375ft/lbs)light weight flywheelstock sr raddual electric fansnismo thermostatnismo motor mountswalbro fuel pumpboost/airfuel/oil pressure gaugeshks super megaflow intake
i think thats it if im not missing anything but how much u think id b puttin down w/ this set-up and is there anything that i should get opinions and advice please!!!!!
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
New water-pump.
thang nguyen
Car: 1989 Nissan 240SX Fastback
list aright for light mods, maybe add in a fuel controller....SAFC so you could slightly tune it.
mirochuki13
Car: 1992 Nissan 240SX Hatch
Throw in an after market transmission bushing, makes shifting a 240 a lot less floppy. Peak Performance sells a nice piece.
blinker_fluid
Car: 1991 Nissan 240SX FB
2000 Nissan Maxima SE
Tires, brakes and a clean windshield. Maybe go for fuel pressure regulator too.
onecrazyfoo4u
Car: 03 Type S
Def. get a nismo fpr, to turn down the fuel psi. It worked out great on mine, the walbro pumps push up the pressure a few psi, and it'll hesitate and make for rough starts.
Also get some gauges to monitor how your motors doing....I'm running boost, water temp, and oil pressure right now. I think those should be the 3 minimum.
callmeweezy724
yea i plan on getting an fpr, safc, z32maf n 550cc injectors too but ijus want to get my motor in so i was jus seeing if it was a good set up until i get these things. how much hp u think ill b puttin down with the mods i have now?
callmeweezy724
onecrazyfoo4u wrote:Def. get a nismo fpr, to turn down the fuel psi. It worked out great on mine, the walbro pumps push up the pressure a few psi, and it'll hesitate and make for rough starts.
i have boost, oil pressure, and air/fuel gauges already
callmeweezy724
miroS14a wrote:Throw in an after market transmission bushing, makes shifting a 240 a lot less floppy. Peak Performance sells a nice piece.
can i get more info on that? please thanks for your help guys i appreicate it.
callmeweezy724
Thoughtful_One wrote:New water-pump.
I will b doing a full tune up new water pump, belts plugs wix z32 fuel filter wiz oil filter etc.
Any thing else? advice n opinions pleaseeeee. lol
