I Finally got a 240(Lots of pics 56k ...maybe ??)
kanye240
Car: 1990 Nissan 240sx Coupe'^2001 jeep grand cherokee
Hey Nico heads ,i just recently acquired a 93 240sx for 1k......she needs a little bit more TLC than usual but no worries on my end
O the first time i tested the brakes ....there was a bottle of antifreeze in the back seat.....mmm lets just say there a puddle of antifreeze on my floor
and this is my first car too!!!!
ill will post the probelms/set backs of the car
tell me yall think peace
Defcon86
Car: 1989 Nissan 240sx and 2007 Pontiac G5
Way to go. You have your work cut out for you. I hope it turns out nice. Any plans?
kanye240
thanx ...... imma gonna make it real nice and clean ..
i mean i dont mind working on my car at all
for now im just gonna fix all the little here and there problems it has .Then Ill worry about modding it
ThuG LyFe
Car: 95 S14
hold up a grand for that?
looks like it rolled off the mountain passes at a touge battle...
i think you should just look for a cleaner shell and swap over the parts.
SeVa-S13
Car: '05 GTO 6spd
Aslong as the frame isn't all rusted out, looks like a great start for a project. Good luck.
Soravia
Car: 2003 Audi A4 1.8T
- Front and Rear Engina main seals- Brake Pads (with Shims), New Rotors, Rebuild or replace calipers if necessary. Flush brake fluid.- Flush Transmission fluid and replace filter.- Change engine oil and use no cheap filter( FRAM) but good ones.- Put the car on lift and inspect for rust. Remove any rust ASAP with drill gun and wire wheel. Paint with primer and cover with Rubberized Under coat.- Replace Shocks and struts. Fill Strut mounts with grease to prevent rust. Even if there is a cover.- Replace Tie-rod outer ends and check for worn boots on the inner end.- Replace thermostat.- Pull off the vavle cover, remove timing chain guide before it falls off and wreck the engine. Replace the timing chain tenshioner.- Replace the valve cover gasket.- Replace Spark plugs with NGK ONLY. No BOSCH.- Replace Air filter.
You're good.
georgegto
Car: Nissan s13
Bad choise of buying that..u will spend a lot of money for repairing it before u start spending money for tunning\styling parts..
slipstream_pnoy
Car: 95 Nissan 240SX
Soravia wrote:- Front and Rear Engina main seals- Brake Pads (with Shims), New Rotors, Rebuild or replace calipers if necessary. Flush brake fluid.- Flush Transmission fluid and replace filter.- Change engine oil and use no cheap filter( FRAM) but good ones.- Put the car on lift and inspect for rust. Remove any rust ASAP with drill gun and wire wheel. Paint with primer and cover with Rubberized Under coat.- Replace Shocks and struts. Fill Strut mounts with grease to prevent rust. Even if there is a cover.- Replace Tie-rod outer ends and check for worn boots on the inner end.- Replace thermostat.- Pull off the vavle cover, remove timing chain guide before it falls off and wreck the engine. Replace the timing chain tenshioner.- Replace the valve cover gasket.- Replace Spark plugs with NGK ONLY. No BOSCH.- Replace Air filter.
You're good.
Damn thats a long list, he go his work cut out for him. good luck
Soravia
georgegto wrote:Bad choise of buying that..u will spend a lot of money for repairing it before u start spending money for tunning\styling parts..
Absolutely not true. I spent well over $3,000 on my car all in all and I can take on any other $3,000 h0m0 Ricer Civic with wings for performance, reliablility and control.
The list I just did will cost only $1,000 or so. There is no need to pay for a mechanic, all you need is a place, 4 jack stands, floor jack and a rental engine hoist.
Just don't damage your car by jacking at the wrong place.
ilovenissan
Car: 89 Auto 240sx Hatchback...yes, AUTO
Good luck on your plans for the car it definitely needs some TLC but if you're up to the task it will be rewarding oh yeah it's an auto like mines so you get 10 cool points!
574-240sx
Car: Nissans, Toyotas, Subaru
Good luck fixing everything. Reminds me of my old hatch, it was the same color. The color is pretty rare only available in 93.
I also have a driverside door the same color in good shape if you are intrested in it.
Also nice Cobra parked next to you.
Soravia
I recommend working on the car all at once as much as possible. You can save a lot of time and money that way.
example. You can rent an engine hoist and lift the engine to replace front and rear main seals to stop oil leak (or prevent if not yet leaking oil). You can replace thermostat, valve cover gasket, upper timing chain tensioner, and oil pan gasket, power steering feeding hose, coolent tube, motor mounts at the same time.All those part may not be bad right now but your car already has 175k on it. They will fail soon and if you replace them one at a time the labor or time will be more than the parts themselves.
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
i would have barely gave $300 for that thing. thats all its worth....
anti_flag_army
Car: 91 Miata, 90 240sx coupe
I paid a grand for my 240, and it was a 5 speed with no problems and new paint....
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Decent, she needs lots of love. Hope you didn't pay more than $750 for it with all those dents and cosmetic problems. The interior needs DR. Vroom-Chirp as well.
xtrmnop
Car: 91 240sx Hats & 2003 Acura CL-S 6spd
Not bad, car looks better shape than my 91 that I got for $800. You're gonna have fun fixing it up.
TrueVillan
Car: Black 95 Zenki
I dont think I could of bought that........but everyones diff so good luck with the build up and please give your ride some love man...hope shes in good hands.
Juanizzle
Car: 90 Hatch
i would have paid $1000 for that. IF IT IS RUST FREE & 5SPD.
/caps
chicago sucks.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
roof damange = the FAIL
Good luck with it though!
Snowman
Car: 93 240sx
car looks like a weathered old boot. like said above id do all the basic stuff.. then i would get started on bodywork lol
Juanizzle
Car: 90 Hatch
oooooooooor.
you could leave it like that and do all the power upgrades LOL.
SR, GT28r, big brake kit, exhaust, tune, ect. TOTAL SLEEPER.
i can picture it already.
mustang dude @ red light :"HAY THERE BOY. WHAT CHA GOT IN THERE?"
you : "an old beat up POS with exhaust and rims."
Green Light you = gone.
unless its a dude in a 5.0 with boost. then ur ****ed.
hiimelvin
Car: 1991 Nissan 240SX Hatch
2017 Mazda 3 GT Hatch
Good luck with it. At least you picked up a 240sx. I hope you will try to work on the things it needs done before what you want to do to it. Be smart and have fun with it. Saving beat up hatches
kanye240
Thanx for all the positive reinforcement dudes
Yeah,I know its quite the project but Ive seen worse turn out better , so no worries on my end
I tried to clean the carpet and it didnt even help at all
You guys know where i can a new carpet mold ?-------------------------------------------------------- Soravia : severely noted post
i figured those maintenance issues might arise
you think i should just buy the whole timing chain kit while im in there ? since it comes with most of the parts ?
574-240sx: i am interested but i gotta fix the other issues first
yeah imma try to park my next to him every chance i get just to see what he says ( hes like my age too )
Modified by kanye240 at 7:22 AM 9/17/2007
mirochuki13
Car: 1992 Nissan 240SX Hatch
Damn... what happened to that hood?
But definitely not too bad for 1k.
kanye240
im not sure ,looks like it flew up and hit the roof cuz theres a damage where the hood might have hit .on the roof ......no biggy it will be gone on saturday
Dr.Fate
Okay brother Here is what I like:1. I like to see more brothers doing the damn thing with s13's2. Don't feel like you got beat out on the ride no matter what! it can get fixed.3. Take care of major stuff first in this order: Rust, Suspension, Brakes & rims , Powerplant choice, Interior and then body.The reason I love the silvia is that a lot of the brothers don't know about this car and when I take her in hood to get a hair cut I always get WTF! is that! I love the remarks like " dat sh(t looks like a old school bmw" ( I just bust up), Then when I tell them how much it costs, they look at there cars (Dodges, Hondas, Chevys and suv's with rims) and go Damn!, I could have had one those instead of this? Hell I got two brothers right now looking for Coupes and the onwer of the shop just got a 91'RX7 just to show me up! Anyways I like seeing more African americans doing the damn thing with the s13. Peace, and LONG LIVE NISSAN! P.S. don't get chrome rims before shocks and springs! Fight the urge! I did !
Uberck
Car: 240sx
ugh, 1000 for that?
gosu22
5spd manual swap up in dat OH!
JackIrish
Car: Restored 1986 300zx / 1992 KA 240sx Project
Even though it needs some work, it still loops better than the mustang it's next too!
biggee247
Car: 1993 240sx Se Super Hicas
Hey antiflag, What type of wing is that on ur 240sx and how much do you think that would cost? The one that is on ur signature.
