JDMricist wrote:I'm using NGK Iridum plugs that don't need to be gapped (even says on the front of the car)
False, they need to be checked at the very least. Be cautious though as the electrodes are delicate. Using feeler gauges, if the gap is supposed to be a 0.045", then use a 0.043" to check.
0.045" is going by memory for an NA, I'm not sure what it's supposed to be.
Did you do a power balance test? Search for how to do that, if you have a problem cylinder that may help you find it. Any ECU codes?
