Oh I was going quite slow actually.. in fact I eased into it and just didn't notice my door was open cause i was reading the mail i had just grabbed... anywhoo... I got some pictures with the door closed. I know the door is being pushed out by the middle adjustment hinge.. The fender is defiantly smashed inward though from the side of the door hitting it...I doubt that the fram is messed up.. I really think the hinges are out of line. I still have faith that I can fix this myself If I could be pointed in the direction of how to remove body panels so I don't mess that up somehow too..240sxAli4Life wrote:Ouch! Hopefully its just bent hinges, and nothing major. How fast were you going when you were backing up?
Ok thank christ.. I'm gonna see if I can replace the hinges then. I'll look at the fsm again for the fender removal I guess. I'll check back in if I have some more Q's or once I finish.. Whichever comes first.Morph wrote:Your good bro, my friend had the same thing happen except it was another car instead of a building, and we had to replace some hinges and it was fine.
Dont feel bad we all do dumb crap, hell most of us have 240's.
Ok so its body shop first thing tomorrow then. Thanks for the link and the help guys.AZhitman wrote:^ Good idea.
Door removal... Definitely need to pull the fender first. Start with the bumper (it's self-explanatory).
Here's the FSM chapter that deals with removing the door. http://www.nicoclub.com/FSM/240sx/1996/bt.pdf
Have a friend there to help support it as you remove hinges (go get new hinges first!)
pm'dfiznowler wrote:I probably have a set of those hinges laying around. I just parted out an s14. If ya end up needing let me know and I will send em to cheap.
